Heating & Cooling Logo
H
Hans woeginger Posted on Jun 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Amcor amb 12000e, starts to cool and after a few minutes the unit "shudders" and starts to heat. Not sure why, please advise. Thank you
Steve P
Level 3:
  • Amcor Master 3,912 Answers
  • Posted on Jun 19, 2017
Steve P
Amcor Master
Level 3:
Answers
3912
Questions
5
Helped
1305754
Points
15904
You are almost out of freon... call a service co... DO NOT run this unit until you get it charged.
2helpful
Override temperture setting on Amcor Amc-12000e portable Air Conditioner
Actually there is no way to do what you want because the unit is designed to operate when the inside temperature allows the heat exchanger to function so that it will condense the liquid refrigerant into a gas.
As far as using it in the winter to dehumidify this same applies. If it is to cold then the gas won't be able to condense back into a liquid. If I were you I would buy a portable dehumidifier but remember that if the temperature is to low it won't work.
Good luck
Marty
I have an AMCOR ALTL1200E, fan works, cold air comes out when the compressor turns on BUT after 5 minutes compresor turns OFF, then after 5 minutes again it turns on, what is wrong, thanks
Sounds like the unit is cycling off on a high head pressure (condenser coil too hot). When the condenser cools, the automatic switch resets. The unit cuts off again when the condenser heats up again. Clean the condenser coil, and clear out any debris (bird's nest, lint etc.)
Get cool at the beginning but then it starts blowing hot air. Is the a way to recharge the AC or what can i do to get it cool again
Check the thermostat. That could be the whole problem. Otherwise, you may need to have it recharged or serviced.
I have a AMCOR CPLMB 12000e A/C that runs but doesn't cool. Where can I get it fixed?
KD Grayson Heating & Air Conditioning
916-640-6693
Always a flat rate for a diagnostic $29 Anytime Any day! 9e28e716-b18a-414a-86c2-4e8057e9d403.png
Amcor 12000-E air conditioner will not emit cold air. all filters are clear and hose is vented to outside. I'm about to boil
Hi, I'm new here but have the same model. Is your A/C new? Is your "Mode" set to "Cool" rather than "Fan"? Is the temperature set below room temperature? If not it will just run as fan. Lastly is your water reservoir full? Probably not the problem as the unit will shut off. Looks like you posted this a couple weeks ago, hope you figured it out.
Tim
Top Amcor Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
