Question about Kodak EasyShare V1073 Digital Camera
Kodak v1073 lens cover won't open when camera is turned on
    President:
  • 2,761 Answers
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 15, 2009
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
Kodak V1073 Digital Camera lense will not retract and immediately turns off once powered on.
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional. Use these at own risk as it may further damage the camera. Firstly, try connecting your ac adapter or usb cable. Try holding the shutter button while switching on the camera.
Look at the lens, and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down). Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair (but as your camera has been dropped this will not apply). If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
You can also have a look at THIS link.
Hope helps.
Jul 02, 2011 | Kodak EasyShare V1073 Digital Camera
I'm having a problem with my Kodak V1073 camera. It has frozen and the lens won't close. I re-charged the battery and also tried taking out the battery and plugging into the wall socket but still won't...
Your camera most likely has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Oct 04, 2010 | Kodak EasyShare V1073 Digital Camera
Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Mar 06, 2010 | Kodak EasyShare V1073 Digital Camera
My USB cord is connected to my Kodak V1073 camera but, the computer is not detecting it. How do I get my pictures to my PC from my camera?
After you plug it in you have to turn the camera on. Then open the easyshare software and go to "add pictures". But the camera must be powered on for the computer to see it.
Feb 15, 2010 | Kodak EasyShare V1073 Digital Camera
The LCD screen freezes and turns all white then cuts off when taking pictures.
was the camera drop?
are you using the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7004
Here are the steps you need to do
-Try to use your camera without Memory card
-Turn on camera and press the zoom button make sure that the lens will move properly., If camera hungs it means the camera lens is the problem
-If youturn on the camera then it will just display white screen and shuts off when taking picture Charged the battery for 4hrs
-after charging the battery and still camera freeze it means your camera needs of service please call kodak toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EasyShare V1073 Digital Camera
I have the Kodak Easyshare V1073 and when I turn
Scream to Kodak for the money of your purchase be returned to you!!
We, citizens, are up to here with electronics that last enough past the 3 months of warranty manufactured companies offer!!
Shame to all of them!!
L Kilhefner
Aug 10, 2009 | Kodak EasyShare V1073 Digital Camera
No sound on video with Kodak v1073 dig. camera
Uninstall the quictime player from your OS then obtain a new copy. www.apple.com
Jul 06, 2009 | Kodak EasyShare V1073 Digital Camera
Kodak EasyShare V1073 Digital Camera Logo
510 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
