Question about Canon EOS 40D Digital Camera
40D turns off as I press shutter button
The machines is with the newest firmware 1.1.1 and using a fully charged Canon battery. When I pressed half shutter, it will focus, but when the shutter is fully pressed, the machine just shuts down. It would not open up unless I eject the battery and insert it again. Appreciate for your kind help
  • axolon May 11, 2010
    I have the same exact behaviour on my 40D since yesterday, after only
    7500 exposures. If you found out more about it in the meantime, please
    share it with us. It would be greatly appreciated!
    Thank you!
    Novelist:
  • Canon Expert
  • 357 Answers
This is most likely a motor problem. Canon had a quality control problem with the motors for this model, due more than likely to bad quality control at the Chinese plant that manufactured them. There are two identical motors in this (and more recent model Canons). One ***** the shutter, the other moves the mirror up and down. Both also have phase switches that can become 'dirty' because of the excessive grease put in the gears during manufacturing.
The motor(s) freeze, and you get the problem described. If the mirror goes up and then it fails, it is the shutter motor. If the mirror fails to rise, then it is the mirror motor.
A shutter failure can also cause problems, but it runs about three to one that it is a motor failure.
Posted on Apr 30, 2012
    Problem Solver:
  • 11 Answers
The shutter mechanism had to be replaced. I've heard that this is a typical 40D problem, due to a shutter design flaw. They say that it has been fixed on replacement shutters.
Posted on Jan 30, 2010
Power failure upon pressing shutter button
hi
dear ur battery is not working properly replace the battery
Dec 14, 2009 | Canon EOS 40D Digital Camera
Canon 40d-pressing the shutter seems to short out the camera.
I recommend that you remove both batteries for ten minutes to get a full reset. you spoke of the main battery. When you open the battery compartment, look at the lower right toward the camera with the LCD facing you.
It is a little hard to see, but will say CR2016 3V. Stick your fingernail under the lip and just pull it out.
As I said I left both batteries out for about 10 minutes.
You will have to re-set the date and time after your done.
Oct 16, 2009 | Canon EOS 40D Digital Camera
Pressing shutter switches the camera off (40D)
Before you send the camera in for repairs, try this free fix. The problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem may be due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Sep 11, 2009 | Canon EOS 40D Digital Camera
Canon 40D not firing
Try doing a reset in the camera tools somewhere, this fixed a similar problem I had.
Jan 07, 2009 | Canon EOS 40D Digital Camera
Err99 40d canon body only
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Oct 28, 2008 | Canon EOS 40D Digital SLR Camera Digital...
Canon eos 40D error 99
Check this link: www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 20, 2008 | Canon EOS 40D Digital Camera
Canon 40D can not turn on
Same problem. Fully charged main battery. In my case, I hadn't used the camera in over 6 months. All I did was pull the main battery and then pulled the small CR 2016 button cell battery located inside the main battery compartment and re-inserted both batteries. The camera made a quiet click and then turned on with the main power switch and asked to reset the date and time. Works fine now. If this doesn't work just purchase a new button cell.
Sep 17, 2008 | Canon EOS 40D Digital Camera
Canon EOS 40D Digital Camera Logo
1,408 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
