Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
No spark on my 14 hp kohler engine
I have no spark on my 14 hp kohler engine the moter is just sitting on the grond i just jumped started it turns over fine just no spark any help
  • kevinplea42 Jul 26, 2009
    so do i have to take the flywheel off
    i dont have a manual of the engine its a k321
  • 5,687 Answers
Sometimes there is rust on the crankshaft and the magneto can not pick up the signal. Leave the sensor on the engine, try cleaning the rust off the crank damper and then run a clean rag between the sensor and crank. The gap varies but a old fashion matchbook seems to work in case the sensor is loose. Good Luck
Posted on Jul 26, 2009
  • fordexpert Jul 26, 2009
    Received your email. A manual would help you find the sensor. You may be able to find your engine online or at a Library. If the sensor is not down at the output shaft, then it would have to be under the pullcord cover. Since you have electric start, you should only have a shield cover. Once you find the sensor you know to clean the rust off of the part it is mounted over.
    Fixya does not give us the capability to send diagrams.
Kohler 15 hp motor turns over but will not run.what is wrong?
take the spark plug out and turn the engine over to blow out any excess gas in the chamber. put in a new spark plug and try again. if this don't work you may have a valve or timing problem. there are many videos that show how to check valve clearance and flywheel key on you tube. if you have gas and spark and compression it should start.
Mar 31, 2018 | HP Garden
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Apr 21, 2014 | John Deere Garden
Engine starts fine. Go to release the brake and it stalls. Snapper pro 61"
u have a bad switch or a wire touching somewhere maybe the sit switch
Oct 14, 2013 | Snapper Pro S200x 27 Hp Kohler 61"...
I have 16 hp Kohler engine with a compression release not working,help.
i have a Kohler 16 Magnum opposed cylinder engine and it wont crank over with the spark plugs in it,battery and starter are both good,its an aluminum engine and i have seen several of the Kohler engines break the automatic compression release on the cam gear and they seem to lock up while trying to start,pull the plugs and the crank fine,Kokler is the most expensive engine i have seen and their parts are outrageously priced,old Kokler was a good engine,newer ones in my opinion are junk,i work at a small engine shop,i have seen new Kohler engines with a broken ACRs,i work at a second job,we got a new supervisor that worked for Kohler before her came to our plant,he said he worked customer service at Kohler and he heard complaints constantly from people using their engines and the returns were out the roof on their engines,what im saying is i wont ever but another Kohler unless itsm an old one,Thanks Tommy
Jun 06, 2012 | Kohler Electrical Supplies
It was working fine until we had a snow storm. The engine quit. After about 15-20 minutes I was able to start it again, but it happened 2 more time, each with a 15-20 minute wait in between starts. It sat...
i had the same thjng happen after much $ it was the coil. the snow would make the engin compartment moist and the coil wuld jump spark to grond from the coil wire and were it plugs in to the coil . the fix new coil and the coil computer thats on the coil itsself .to check this open hood find coil start engin then spray water from a spray can on top of coil and look for jumping spark. good luck.
Feb 10, 2010 | 2000 Chevrolet Astro
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The engine is cranking want start
check for fuel .? spray staring fluid into throtle body then crank if engine runs then stalls you have fuel related problem ( fuel pump) if no start you have ignition problem ( coil or distributor check for spark use a screw driver insert into spark plug wire at spark plug end hold about 1/4 away from gronded engine and crank engine see if spark jumps gap if no spark could be coil or crank sensor
Feb 26, 2009 | 1993 Subaru Impreza
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
2,997 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
Craig Butler
Craig Butler
John Trevino
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
