Question about Kenmore Elite 45986 Front Load Washer
Smells like rotten eggs
I have this washing machine and a smell of rottten eggs is coming from the machine. A friend siad there is some type of pan underneath that may cause this small...Does anyone know anything about this issue?
The smell of rotten eggs normally means you have some water that has been sitting arround awhile and has gone bad. You may have to unplug your machine and remove the front cover to take a look arround the inside of your machine to see if any water has leaked out and has puddled up. You may also have something caught in the drain pump's filter, which may have gone rotten from sitting around too long. This filter is easy to unscrew and gain access to once you have the front cover off. Make sure you have lots of towels or a wet vac handy when you unscrew the filter cover.
Posted on Jul 28, 2009
We followed me84401's recommendation and found a baby sock stuck in the filter with a ton of lint and other gunk around it. The "front" of the washer that you remove is the area below the door.
Posted on May 23, 2010
  • packman38506 Feb 26, 2011
    I have the same washer and have the exact same issue. I paid a plumber $150 to put a vent on the drain under my house and it didn't help. I too cleaned out the front filter and found coins, lint and sludge, and it appears that the smell is strongest in this area. Thought I had fixed it but the smell continues. I just cleaned out the filter again and the smell is unbearable when you take the filter cover off. I'm at a complete loss as to what causes this issue.
    Problem Solver:
  • 14 Answers
You might have a small leak coming from the outlet hose
Posted on Jul 26, 2009
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
How to get rid of rotten egg smell coming from washing machine
Check the drain where the wash machine is plumbed into it should have the blung to stop the smell comming out of the drain,also check the filter but it is very rare that the smell will come out of the washer it will be a drain issue that is backing up through the washer,if you havent got a u bend trap on the drain it will allow the drain gases to come back into the house.
hope that helps a little bit.
adrian
May 28, 2014 | Hotpoint Aquarius WD63 Front Load...
it is happen to old engine because the oil that escape from the engine(engine cover near the exhaust) when it is got hot it sends bad smell but after how many minutes if it already dried up because of heat it will gone (like frying using the used cooking oil in pan there is a different smell).
Sep 19, 2013 | Mitsubishi Cars & Trucks
Car runs ok, but gets hot and rotten egg smell comes out of the exhaust
If car runs okay with egg smell, its normal and working the way it should, if car is running poorly and the rotten egg smell has gotten worse, its a sign that your exhaust catalytic converter will need to be replaced. good luck!
Aug 12, 2011 | 2001 Oldsmobile Alero
My 2002 Pontiac GP V6 smells like rotten eggs from the exhaust
The rotten egg smell if it is coming from the exhaust is a very good sign that you catalytic converter has failed or is failing. but a bad or battery that is being overcharged can also make a rotten egg like smell.
Jun 05, 2011 | Pontiac Grand Prix Cars & Trucks
The washing machine smells like rotten eggs on the rinse cycle. The clothes also smell afterwards as well. What can I do to resolve this?
Rotten egg stench is caused by sulphur content in the water or building up over time in your water heater. It can also build in a water system that is rarely run. Have you noticed this smell from other taps in your house? There are inline charcoal filters that can remove it from the water, or you can also try removing the water lines from the washer and running them awhile.
Is this new, or has it been happening for awhile?
Dec 04, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
After about 18 months, washing machine smells like rotten egg/fart. Is there anyplace to clean it out?
If you have well water, Check your "Annode" Rods in the Hot Water Heater. Had mine do this. I had to Replace the Whole thing as it built up to much Contaminents from the "Hard" Water.
May 12, 2009 | Washing Machines
Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Jan 21, 2007 | LG WM-1832C Front Load Washer
Egg Smell
We fell prey to the same desire to have the state of the art, economical and supposedly gentler on your clothing front loading washing machine. Bosch WFK 2401 and I have found a solution but it is not pretty for those of you who have a washer not hidden in a laundry room.
I keep the kick plate off at the base of the front of the washer. Using a low profile pan, an 8 x 8 cake pan is about right and immediately after every wash plase the small drain hose over the pan and open it. The pan fills about half way with water that is left in the bottom of the drain system. Doing this prevents the next load from being exposed to the rotten egg water.
It must be done at the end of every load. I too keep the front door open when not in use and pull the detergent/softener draw open as well.
Good luck. Can hardly wait to justify that I have lived with this long enough to purchase a new top loader!
May 09, 2006 | Kenmore 24832 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
2,110 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
