Question about Euro-Pro Steam Penguin Hard Surface Steam Cleaner Vacuum
Steam penguin won't pump steam out - Euro-Pro Steam Penguin Hard Surface Steam Cleaner Vacuum
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
Can the nozzle get blocked and affect the pressure of the steam
Yes particularly if you use hard water (high in mineral content)
Aug 09, 2014 | Euro-Pro Steam Penguin Hard Surface Steam...
What to do when blue light is on and water wont come out the steam penguin
Blue light comes on top of penguin gets hot but the water tank stays cold no steam
Oct 28, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
Won't **** up water
please go to :http://hoover.com/support/video-instruction-guides/
see the instructional videos, and proceed with commmon sense for torubleshooting.
You must clean the tank , maybe is full and need emptied, or blockage.repair. or pump-motor.
God bless you
Jul 15, 2012 | Hoover F5906-900 Upright Steam Vacuum
My Hometek Steam Penguin wont produce steam
Hi
I opened whole thing and found that no suction to the pump or pressure from the pump. Opened the clear box which contains the pump and the el-motor. Then I opened the white pump and found it was assembled wrong way round. There are two tiny one way silicon "valves" which should produce the flow of the water to the heater. I also wiped off part of the sticky grease away. Now it works. 4 hours work, but it was interesting to learn the function :) .
Anssi
Apr 09, 2012 | Euro-Pro Steam Penguin Hard Surface Steam...
I have lost the instructions for my sons doodle penguin, have you a copy you could e-mail one to me please.
i do have a pdf document of these instructions, but this site won't let me attach it, give me you email address and i'll pass on
thanks
Jan 24, 2011 | Vacuums
Euro-Pro Steam Penguin Hard Surface Steam Cleaner Vacuum Logo
137 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
