Question about Roland Music
It's a Roland HP-7e digital piano about three years old.
Some notes much too loud. Could the pads/contacts under the keys be worn out? It does get heavy use. If it's just dust, how do I open the piano to clean it?
  • Roland Master
  • 5,603 Answers
You may need to clean the contacts which are usually conductive rubber. I explained stuff for another Roland problem with two keys that were intermittent. I have an EP-7 that I had to do the cleaning of the key contacts. Use 91 or 99 % Isoprophyl alcohol to clean BOTH the conductive "pill" (Black under silicone rubber domes) AND the traces on the board where they press. Clean gently as the traces have a hard black coating.
Posted on Jul 29, 2009
Keys on yamaha digital piano are sounding more than one note at a time how can i fix this?
The keypads can develop dirt , failure of pads which can result in such malfunctioning. If you are able to open the piano then carefully remove the keypads , clean the surface and reset.
this must solve the issue unless the pads/springs/mechanism are having fault.
Jul 05, 2011 | Roland Hp337 Digital Piano
Roland Piano 600 HP 600, out of 76 keys, Keys# 4, 9, 10,11,12,13,14,15, 23, 38, 74 will not play( no sound). Any ideas? Everything else works. Have taken no actions to fix yet.
There is a rubber "bubble contact" strip under the keys, and pressing on a key pushes the bubble down, which makes contact with the circuit board underneath. Any foreign matter that gets in the way of this contact will render that note unplayable, and that is likely what has happened. You can remove the keybed, remove these strips, and clean the board with rubbing alcohol. Don't use alcohol on the bubble strips, as it is not good for the rubber.
Sometimes, you can simply tape a small piece of cardboard, like from a cereal box, onto the bottom of the key where it pushed on the bubble, and this can fix the problem.
The bottom line is that you will have to remove the keybed, and that may be a daunting procedure unless you're used to that kind of work. So you may want to just take it to a service center. You can get parts at www.syntaur.com. Good luck!
Feb 25, 2011 | Roland Ep760 76Key Digital Piano
How to remove piano keys from Roland KR 4700
You probably need to just clean the circuit board and the conductive rubber contacts. There are two per key to facilitate reading the key velocity.
Use 99% isoprophyl alcohol and Q-Tips to clean both the board and the rubber contacts.
A rod is inserted lengthwise to hold the hammer weights while removing the boards. Use dowels from each end inserted about halfway back between the keys and the weight rods. Use a 1/4 inch dowel rod.
You have to take out a few screws to remove the boards from the key assembly. Be careful of the cables.
Mar 17, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
I have a Roland HP 101 digital piano however certain dont sound
White spirit is NOT what you should use. Mineral spirit leaves a residue film.
Use 99% isoprophyl alcohol.
ALSO inspect the contactboard for cracks by candeling with bright light behind it.
Oct 31, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
What type of sustain pedal Roland EP-90 digital piano is using - open or closed at rest?
CLOSED is typical for Roland pianos when at rest. (open to sustain).
Note that the jack PROBABLY has a grounding contact so when no pedal is used/plugged in, the jack is shorted at the piano.
Sep 19, 2009 | Music
Have a HP 1700 Roland Digital Piano that has one key (first G to the right of middle C key) that is off.
It sounds as if the membrane under the key needs to be replaced. It can be done with some careful work yourself but you might want to consider having it serviced by a Roland dealer as apparently the parts are becoming scarce. Hope this helps.
Aug 18, 2009 | Music
I have a Technics digital piano with 1 dead key. The piano is about 10 years old and in great shape. The key stopped working after my toddler started banging on the keyboard. Is this fixable?
If your piano is the same as mine, there is a rubber membrane with contacts imbedded in it that sits on top of a circuit board. The key pushes the contact in the membrane onto the contact causing a note on. What happens is the cylindrical part of the membrane that holds the contact can get torn and the contact will no longer travel in a straight line to trigger the note. The entire membrane strip has to be replaced. The strip on my piano was discontinued and I had to manufacture one from an extra Roland membrane that had some bad contacts in it. You will have to contact Technicsat www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd for support. If you don't feel comfortable tackling the repair yourself consult a good piano tuner/repair place in your area for advice.
Jun 22, 2009 | Music
Roland 3000 Digital Piano 88-Key Full-size weighted keyboard
It's not really for the faint of heart, but generally this is caused by gunk getting into the key circutry. Underlying the 3000's keyboard is a silicone pad with 2 contacts on it, the measurement between each being hit is the issue usually but yours just sounds like there's something in there causing a physical or contact obstruction.
What you really want to do is to remove the keys and clean everything but this isn't easy... You could try using 99% alcohol (from a pharmacy) to clean inside it which may well help you.
There's a good thread on a similar issue at:
http://www.electronicspoint.com/roland-hp-3000s-digital-piano-dodgy-note-t18946.html
Which may help you work out how to do the disassembly if you are brave, but I would start with pouring some alcohol in and poking it and hoping for the best 1st. It sounds crude, but it works amazingly well with some things.
Dec 29, 2008 | Yamaha NP 30 76 Key Lightweight Digital...
Music Logo
1,144 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
