Question about Brother 1034D Mechanical Sewing Machine
Hi, I need to replace the internal piece that actually lowers and raises the presser foot. It is a plastic piece that fits on the end of the rod. What is this piece called and how can I get it? Because it is plastic and fits on the rod the movement of up and down has warn this piece out. Help?!
  • 2 more comments
  • Anonymous Mar 29, 2014
    The inside ring keeps falling out
  • Jan Egan
    Jan Egan Nov 14, 2016
    Please know that Pressure Foot Shaft Assembly XB0876001 is only 7" in length with a white plastic tipped end for the shorter outside plastic body of the 1034D Serger and will not work for the larger outside plastic body of the 1034D Serger. You will need the original Part Number, XB2208001 which is longer at 7 5/8" and has a black plastic tipped end. I don't know why Brother changed it....still searching for the original to fit it. Confused and Frustrated!
    Call Warranty Dept at Brother....they will give you a phone number for service in your area.
  • Jan Egan
    Jan Egan Dec 03, 2016
    do you have the white tip or the black
  • Jan Egan
    The rod and plastic piece or one part...they come attached. you can not replace just the black or white plastic piece.
I just replaced mine. wasn't hard at all. I couldn't find just the plastic part, had to buy the whole thing. First it is called a Presser foot shaft assembly, part #xb0876001. You can buy it from Sew4Less.com and it cost me 25.57 with shipping. You will have to remove the front cover and take out the two screws holding the bar in. You will also need to remove the lifter bar and end panel to get the bar out. Insert your new part and replace the covers and lifter bar. This is how I fixed mine. Hope it helps.
Posted on Nov 13, 2012
  • 55 Answers
To replace this part you must remove the presser bar - take it to a tech.
scott
Posted on Jul 27, 2009
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
My Brother 1034D Serger presser foot lifter just spins. I had read that its just glued into a little plastic piece. Has anyone had this same problem and if so did you just glue it back? Did it wor
I had the same problem a while back and ask here. I was told to take it to a tech. Not the answer I was looking for. I did some searching and found a diagram then knew what I needed. Here is my reply...
Jan 14, 2015 | Brother 1034D Serger Sewing Machine
Pressure foot will not lift up
do u have an automatic machine meaning ft is lifted by pressing ft pedal a certain dirtection. otherwise tilt machine and push knee lever. there should be a flat oval piece on top of lever rod. does it rise straight? it needs to contact the push rod on the machine presser ft. see if the line up by lowering the machine slightly. if not bend rod to aglin. your knee lift may need adjustment too and maybe the presser ft screw located by removing the rubber plug on side of machine or take off the plate by removing 3 screws. careful with gasket cause machine will leak if u tear gasket.. presser ft screw is easy to find. lower ft and tighten. make sure that the needle is centered in foot slot when adjusting presser ft screw. otherwise thread will break when needle hits side of presser ft. a very common problem that many do know about and someday i will charge the site. 35 years with juki and still going strong.
Apr 22, 2014 | Juki DDL-8700
Raising presser foot on Janime 2212
http://content.janome.com/userfiles/file/Inst%20book_%202212%28En_Sp_Fr%29.pdf
See p. 10 of the manual.
The presser foot lifter is on the right side of the leftmost part of the machine, towards the back of the machine. Press up to raise it.
Feb 16, 2014 | Janome Sewing Machines
I cant figure out how to install the buttonhole foot
Do you just need to attach it to the machine? Or are you having trouble using the foot itself?
It attaches the same way the other feet attach. Remove any foot that may still be attached to the machine. On the buttonhole foot look for the small silver pin that sits on the sliding piece with the small red line marks on it. Lift up your presser foot lever and attach the buttonhole foot's silver pin the same way you would attach any other foot.
As far as using the foot itself place your button on the back sliding piece snuggly till it fits in without falling out, adjust as needed. Pull the bottonhole lever down (it's located on the machine opposite the side of the presser foot lever) so that it rests behind the first lever on the buttonhole foot (small plastic piece raised on the left hand side of the foot that doesn't move). Slide the feed dog switch on the back of your machine so the feed dogs go down. Select your stitch and go. The machine automatically stops when done.
Hope this helps!
Feb 11, 2011 | Brother CS6000i Computerized Sewing...
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
How do I install my darning foot?
First, raise the presser bar, remove the presser foot, the presser foot holder and screw.
Turn the handwheel to bring the needle to its highest position.
Place the darning foot on the presser bar and make sure that the metal bar of the darning foot is above the needle clamp and put the screw back on and tighten.
As the needle bar raises and lowers, the foot will hop up and down slightly.
Make sure that you always lower the presser bar when using this foot. Lower the feed dogs also if your machine has this feature.
Aug 20, 2009 | Kenmore 15343
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Open Questions:
See all Brother 1034D Mechanical Sewing Machine Questions
Brother 1034D Mechanical Sewing Machine Logo
254 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
