Question about Moen Plumbing
Lost volume/force power
Have mod. #3371/3600 therm/volume control. Have lost volume power. Have tried CLR with no help. Noticed that while depressing central button I can pass ''temp. zone'' and volume power increases but so does temp. to very hot.How can I increase the power to it's original force? Had 3/4 inch plumming installed prior to installing. HELP!!!
  • 117 Answers
Did you remove the shower head and check to see if there was sediment in the shower head? also you might want to check the cartridges in flow control on it sometimes they get junk in them
Posted on Jul 28, 2009
Coby 8127 forgot pattern pass code S/N 043130000741
1. With the pad OFF depress the "-" key on the volume control and the power button at the same time and HOLD them down until the "Coby" splash screen comes up. 2. KEEP HOLDING THE "-" key down and RELEASE the power button until an android is displayed lying on its back. 3. RELEASE the "-" key and press the " " key on the volume control You should see the Android system recovery options on the screen. 4. After the menu appears, select the "wipe data/factory reset > Yes " menu item by pressing the "-" key until the cursor is on the line 5. Press power button to select 6. After it goes through resetting, using the volume key to navigate to the "reboot system now" menu item 7. Select the menu item by pressing the power button to select 8. Your mid9042 will now boot to an unprotected screen, BUT you will have lost any applications you downloaded. You will, however, save all pictures, etc. you have loaded. .
Mar 09, 2015 | Coby MID7036-4 - Kyros MID7036-4 7 4 GB...
Please, somebody help me!! My Samsung SPH-M840 had decided, out of the blue, and from the sleep/stand by mode, to give its self the "Screen Of Death." I have tried everything from a soft couple of tap
you need to force it into master resetwith the device off hold volume up and power until you see the samsung logo then let go of power and continue holding the volume up until you see the admin user menu select master reset with the volume control and press the power button to choose it this should help you
Nov 17, 2013 | Samsung Cell Phones
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
How do I Delete a tab setting?
The usual method is to tab to the point to remove and then either toggle the tab with the set or remove tab key.
Nov 09, 2009 | IBM Wheelwriter 30 Typewriter
Speaker volume too loud
Have you tryed to turn down the sound volume on the media player its self as well as the the main volume?
Jun 21, 2009 | Dell 5650 Computer Speakers
Themostat problem no power
Your R terminal in your air-handler is the 24v power that goes to the tstat. Look at the air-handler and match the color wire. ALL tstats have a power wire going to them. If you aren't getting power, you probably have a break somewhere in the wiring close to the thermostat you are replacing.
Apr 07, 2009 | Ruud UBHC Air Conditioner
My GT Logitech Driving Force GT wheel does not work. The pedals d
try this fix. The pedal issue is common with the Logitech Driving force series wheels. Also try going into Controller settings within the Grid game and set to configuation that suits the wheel that you have. http://merc460racing.com/GT/repairing_logitech_driving_force.htm
Feb 20, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Duo-Therm by Dometic Thermostat
red and white are positive and neg 12v
green is low fan
grey is high fan
yellow is cooling
blue is neg 12v(marked B-)
May 17, 2008 | Dometic Rooftop RV Air Conditioner
Duo Therm Air Conditioner Mod. 59136.331/ Control box E 6360360
Something wrong with your thermostat, but if you are using a electronic thermostat and have the indication of supply like light in your control then you can replace the miniature relay that triggers the cool mode of the unit. But no indication of supply try to check the fuse, then if not works you to replace new thermostat.
Dec 18, 2007 | Heating & Cooling
Plumbing Logo
69 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
