Question about HP Pavilion Media Center m8425f 2.66GHz Core 2 Quad Q6700 3GB 1TB DVDRW DL LS GeForce 8500GT Vista H... PC Desktop
Black screen error boot manager missing
Tried to reboot, All I get is missing boot manager. Tried to restore from a back-up disk but that didn't work either! HELP!!!!!!!!!!!
  • 53 Answers
Sometime system restore wont work other solution might be to pop in your Xp or Vista cd assuming thats what you have.... and shut the Computer off and back on at start up during the first screen usually press F8 a couple times and select Option A and try the first option it gives you after that and continue down that list if it don't work then a reformat is the solution usually...
Posted on Jul 26, 2009
I was restoring my emachines W3609 and the power went off. Now it won't reboot...Says missing boot Manager. Even a boot disk and restore disk doesn&#
Start the computer up, when you see the splash screen hold the ctrl key down then depress the F-10 key on your keyboard at the same time.
Terry
Sep 11, 2014 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Windows 7 boot manager missing after buying and loading restore disks from hp
The error befalls when your PC is unable to interact with Windows due to the corrupted Windows installation, or it is trying to boot from a wrongly configured or improperly connected hard drive or flash drive among other external medium...... read more
Aug 31, 2012 | Computers & Internet
Toshiba 5205-S705 is giving an error msg boot.mgr is missing..i tried booting from xp through cd rom but didn work tried to boot with usb as well but didn work any solution pls mail prashantaishu@gmai
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 13, 2012 | Toshiba Satellite 5205-S705 Notebook
My compaq presario cq56 will not restore itself to factory default settings
U have a nasty bug in there. Your best bet is using another computer download the latest malwarebytes program onto a usb stick. Using the hiren disk boot up to the fake desktop, navigate to the usb stick via explorer and run the program and get the latest updates for it at same time. Then run it and clean out the crud that is in the machine causing havoc.When you reboot go back into the program and permanently remove the deleted items that are in the quarantine area.
Mar 03, 2017 | Compaq Presario CQ56-115DX Laptop
Windows 7 won't bootup, has error recovery. it loads files then nothing. screen is black.
Had that problem a few times myself.
Only way I could fix was to restore back to factory condition.
As you boot, watch bottom of screen closely.
depending on system, Should need to press F2, F10, possibly F12, might even be Del.
Most likely you didn't get restore disk, or have made one.
If you do, insert disk before boot up. System should boot to DvD.
Don't forget once restored to update.
Hope this helps
Don
Jun 22, 2011 | Computers & Internet
Blue screen keeps coming when going in to windows\r\nand rebooting, updated the bios, and tried other memory in it but still blue screen
this is becuse of the error in the hard disk remove the error hard disk and conect as slave to a working computer make the working harddisk as first boot my clicking boot in bios right click my computer and click manage then click disk management you will see the two drive partition now scan the faulty hard drive or format the drive and install the windows
Nov 17, 2010 | ASUS A7V600-X Motherboard
Unable to reinstall OS for Compaq Presario 5000.
Use ontrack disk manager
select advance installation
make partitions own do you want
after the completion process
take reboot
now install operating system that you like
even 98 or XP.
It will work 100% guaranteed.
Thank You
Aug 09, 2009 | Compaq Presario 5000 PC Desktop
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
HP Pavilion Media Center m8425f 2.66GHz Core 2 Quad Q6700 3GB 1TB DVDRW DL LS GeForce 8500GT Vista H...  PC Desktop Logo
231 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
