Question about Dryers
My Inglis dryer will not start when the start button is pressed. I've checked the starter switch with a continuity tester by touching one probe to CO (black) and another probe to NO (white)--it doesn't light. With the probes touching and the starter button pressed it does light. Does the switch need replacing?
  • jerrym_austi Jul 26, 2009
    BTW, there are 3 terminals--the third is C (blue wire)
    President:
  • 1,776 Answers
No. Judging from what you are saying, the switch seems to be making. First, I would check the thermal fuse. It is usually located just inside the back of the dryer, mounted on or near the exhaust duct. It's about an inch long and can be checked for continuity. If it has none, it is bad. Second, you could look at a faulty door switch. It is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or the front of the dryer to access the switch. You can test it the same way you tested the start switch. Hang in there!! You'll find the problem. Hope this helped and best wishes.
Posted on Jul 26, 2009
Dryer has power. controls light up, but when i push the button to start it it won't start.
Label each of the two (sometimes there are three) wires leading to the start switch so that you will be able to correctly reattach them later. Using caution, remove the wires. They are connected with the use of metal slip-on connectors. Grasp the connectors and pull firmly from the connectors. Do not pull on the wires themselves. You may need to use a pair of needle nose pliers to help you.
Use your ohmmeter to test your switch for continuity. Begin by setting your ohmmeter to measure resistance at a scale of R x 1. If yours is a two-wire switch, touch one tester probe to each of the switch's terminals. You should receive a reading of infinity. While the probes are still touching the switch's terminals, press in on and hold the switch. The reading should change to zero.
if it doesn't test like this, replace the switch
Jul 12, 2011 | Maytag MDE9700AYM Electric Dryer
I repaced the felt and slides to fix a loud noise. Still had the noise, so based on answers on this site, i just replaced the rear bearing. put the dryer back together and now it will not turn on. The...
Using a screwdriver or similar, slender object, push the door switch in with door open. Try to start dryer. If it doesn't start it is quite possible that the switch was not connected when you finished working on it. Check to make sure the wires are connected to the switch.
If both leads are connected, you can check the switch with a continuity tester. (About $3.00 at your local big box store should you not have one). With the dryer UNPLUGGED connect the clip to one pole on the switch. With the probe, touch the other. The light on the tester should only go on when you push in (with screwdriver) to activate switch. If the light doesn't go on, your switch is bad and needs to be replaced.
Jan 29, 2011 | GE Profile Wizard DPSE592EAWW Electric...
My dryer will not run. When I push the button to start it, it only makes a bussing sound. What is the problem?
Hi. I suspect a failed start switch circuit. Use my procedure below to confirm.
Locate the start switch(Usually located in the control panel housing). it will have two or three wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the start switch, the reading should change to zero.
For a three wire switch, touch one probe to the terminal labeled NC (or CT1) and touch the other probe to the terminal labeled CO (or R1). You should get a reading of infinity. With the probes still in place, press and hold the start switch, the reading should change to zero.
If the switch fails either test, it should be replaced.
  • NOTE_ If the switch proves to be in good operating condition, simply replace the main control device(timer or control PCB)
Jun 12, 2010 | Kenmore 62602 Electric Dryer
The start button does not start the dryer instantly. You have to turn it a few times before it works.
HI, The switch may be faulty. Use my procedure to confirm.
Jan 05, 2010 | GE Dryers
Push button to turn on and dryer does not turn on. Light inside dryer does turn on
HI. This is a possible start switch issue. I would test this switch for faults. replace the switch if it fails the test.
Dec 26, 2009 | Maytag Dryers
Dryer will not start, has power to the internal light
HI. Normally, this will be an issue within the start switch circuit. If you have an interior drum light, and it will illuminate when the dryer door is open, this will confirm that the door switch is ok. Use the test procedure below to confirm failure to the dryer start switch. If the switch passes the test, simply replace the control sector. The control sector can be a timer module, or control board. It must be replaced, if the start switch passes the inspect, and test, below.
Dec 24, 2009 | Maytag Dryers
Dryer will not start. when you push the start it runs but when you release the starrt button it stops.
Hi. The start switch will be the culprit. Use the procedure below to confirm the damage.
Dec 13, 2009 | Kenmore 62602 Electric Dryer
My dryer will not start a wire is not getting a meter read going form starter switch to motor?
HI. The start switch may be the culprit here. Make sure that the wires are connected properly, and not loose or corroded, in anyway. If all is well with the wires, move on to the testing procedure for the start switch, itself.
Nov 17, 2009 | Whirlpool Dryers
The on button on my estate electric dryer won't work
Hi, i would advise to test the start switch, to confirm the damage. If the start switch passes the test, simply replace the door switch.
Nov 09, 2009 | Estate EED4300TQ Electric Dryer
The dryer won't start itself. We have to hold the button in and bash it.
SOUHDS LIKE THE WIRING CONECTIONS TO THE SWITCH ARE LOOSE OPEN UP AND CHECK .
Nov 01, 2009 | Candy CIV60 Electric Dryer
Dryers Logo
481 people viewed this question
Top Dryers Experts
