How do I remove the cabinet on a Kenmore Model 11022882101 top loading washer?
I am trying to replace the direct drive coupling on a Model 11022882101 Kenmore washer. How do I remove the cabinet so I can gain access to the area adjacent to the motor to replace the coupling?
  • 2 more comments
  • engtchr38 May 12, 2008
    cannot figure how to remove top to replace switch on kenmore washer model 11016882502
  • Anonymous Aug 16, 2008
    Cabinet has discoonected from frame on my Ultimate Care II model # LSQ8543JQ0. Being it has fallen off, not sure how it goes back on.
  • Anonymous Mar 13, 2014
    kenmore piggyback washer/dryer. Need to open cabinet to effect repairs. need to know how to remove covers on Kenmore piggyback washer/dryer combo
  • Anonymous Mar 27, 2014
    I wan't to take the top control panel off so I can take the cabinet off to replace the water valves
  • 248 Answers
You need to remove 2 screws in console. They might be in back, on ends or in front ends. If you can't see any, they are under the console end caps. To remove end caps, pry off by pulling caps towards outside from center part of cap. Pry toward you and towards outside. Then remove 2 screws and flip console up and back. Unplug connector to washer cabinet. Remove 2 gold colored clips by inserting straight screwdriver in them and prying back. Make not of their position first. Now tilt cabinet toward you and slide forward and off base.
To replace, tilt cabinet and slide under frame in front. Now lower cabinet on to frame, making sure cabinet is on frame on sides. Re-install clips by placing them in position and pushing down with palm of hand. Plug in connector, lower console and install screws.
Posted on Nov 22, 2007
For the Kenmore 500 (and possibly similar models), you need to release two clips rather than remove screws. Release the console one side at a time inserting a putty knife between plastic end-cap and top of cabinet (blade parallel to floor). You'll have to push about 3/4 inch to release the clip. Do this on both sides, and console will flip back. Follow previously posted instructions for removing gold clips, etc to remove rest of cabinet.
Posted on Mar 16, 2010
I have an Kenmore 70 series washer. It would not Spin or Agiate so after looking to the internent for help I found it may be the washer coupling. I replaced this part, but now it won't spin, agitate or...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Are you sure that you plugged the Lid Switch back in when you put the cabinet back on??
If the switch is connected, I'd also pull the cabinet again and make sure that the Motor coupler is installed correctly. If it isn't, it could be broken again and the washer wouldn't agitate or spin.
Are you sure you connected the motor?
Jan 19, 2011 | Kenmore Washing Machines
My kemore 110.24422300 will fill and drain but no agitation(sp) sorry.
Your washer is a direct drive model. It uses a coupling to transfer power from the motor to the transmission. The pump mounts on the motor also. If The coupling can simply fall apart with age but usually a comforter or rug will finish it off. To replace the coupling you must remove the cabinet. I have the directions with manual and repair videos: HERE
Mar 17, 2010 | Kenmore 24032\24036 Top Load Washer
Hi my washing machine is not working properly,when we close it, not getting start.
Enter your model number(110.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your Lid Switch is broken.
Following is a Whirlpool PDF of the operation and maintenance of top load, direct drive washers with a section on how to by-pass the switch.
Follow the first couple of sections of the following
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
for how to tilt the console back, use a short insulated piece of wire between the two outermost pins on the lid switch and try the spin cycle.
If the washer works, follow the instructions on removing the cabinet to get at the switch and the Sears site to see exactly where the switch is to replace it.
Oct 10, 2009 | Kenmore 23822 Top Load Washer
Lid activator switch is broken. How do I remove the top of the machine to access this. prying up at the corners doesn't work, I can see little screws in there, but would be difficult to access...
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Look in the component section for cabinet and/or control panel.
Following is a description of how to remove the cabinet on Kenmore / Whirlpool top load, direct drive washers.
Oct 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70series top loader: end of spin cycle the
A couple of possibilities.
1. The Brake Cam Driver in the brake assembly (a plastic piece could be broken.
2. The break springs may also be broken.
Following is the Whirlpool / Kenmore installation and maintenance guide for direct drive washers. It has a section on how to access and replace the brake and drive tube.
You'll have to remove the agitators and the drive block. There is a spanner wrench to remove the drive block nut but I've found that a short 10: pipe wrench hooked over one of the nubs on the nut and sharply taped with a hammer will loosen it.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Sep 26, 2009 | Kenmore 24032\24036 Top Load Washer
Drum turns slow and makes a loud noise
Check for a garment stuck between the tubs.
Check the direct drive coupling on the motor.
You must remove the cabinet to do this.
Mar 05, 2009 | Kenmore 24032\24036 Top Load Washer
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer model 70 leaking
More than likely the pump. Very easy fix. To keep from being redundant I prepared a page on direct drive coupling removal and replacement. The pump must be removed to fix this item therefore it pertains to your problem. Plus you can watch for leaks better with the cabinet removed. To read click HERE.
Jan 18, 2009 | Kenmore 22422 Top Load Washer
Remove top from Kenmore 101.24722300 washer
rberliner The complete instructions you can find here: http://www.askgene.com/2007/01/26/whirlpool-kenmore-washer-direct-drive/how-to-remove-the-cabinet-on-whirlpool-direct-drive-washer-2/ Gendos...post back
Feb 20, 2007 | Kenmore 24722 Top Load Washer
Washing Machines Logo
765 people viewed this question
Top Washing Machines Experts
