71122 ac model starts but the fan does not blow any air .shuts off within seconds.
    Problem Solver:
  • 6 Answers
Which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
Posted on Jul 26, 2009
AC blows cold air, fans stop blowing
I think you have a "variable speed resistor" problem, it's overheating. It's an electronic device usually located near or attached to the AC motor blower that controls the fan speed. This is a common problem with aging AC blowers with electronic controls.
Apr 13, 2014 | 2001 Pontiac Sunfire
Furnace blowing warm air, ac overheats
Sounds like it is tripping on it's high pressure switch. This could be caused by a dirty condenser coil, overcharge of refrigerant, or non condensables in the system ( air most likely). I would get a second opinion from a repuatable company, sounds like he's trying to rip you off.
Sep 25, 2012 | Bryant Heating & Cooling
I have a new Salem travel trailer with Dometic products. Everything appears to work fine, but when I run my furnace and it turns on, my fan blows from my AC unit. I have owned 2 other RV's but...
Yes it sure does sound like something may be wired wrong, Could you please reply with model number of your AC unit as well as thermostat model? To find your AC unit model number if you don't already have it, remove your ceiling air filter assembly, and it should be on the base of the roof unit, facing you.
The base of the roof (upper) unit will have a model and serial number, and if you see a control box where all the wiring attaches as well, get model number from that too if you will. Those numbers should make it easier to determine exactly where the problem is. Thanks.
May 28, 2011 | Dometic Rooftop RV Air Conditioner
Blower fan starts fine sometimes circulating fan starts right away then after about 4 0r 5 min the small 3 amp fuse blows and shuts down whole unit. What is this fuse for and why does circulating fan...
Hi WFO9, It sounds as though the fan capacitor is under specs. It is probably losing its capacitance ability, they are usually rated plus or minus 5% of the value printed on the case. If however the capacitor is no longer within the rated specs. the fan motor will draw too much current and will then blow the fuse. either that or after the normal start delay built into the Ac, which is 3-4 minutes, the compressor tries to start and again draws to much current and blows the fuse. have all the capacitors checked and replaced if they dont meet the specs printed on the capacitor case. regards Col www.digitalcontrols.com.au
Feb 23, 2011 | Heating & Cooling
I have a 2004 2.7 6 chrysler sebring lxi. ac blows really cold and periodically just starts blowing warm air. is there a relay or temp. sensor that might be going out and through a malfunction shuts down...
Cooling fans working? If you notice the air getting warm mostly while stopped, probaby cooling fans not turning on. if the fans are working properly, may be low on freon and need a recharge.
Jun 26, 2010 | 2004 Chrysler Sebring
The AC blows on #4 fan setting but doesn't blow at all on 1-3
That is the blower resistor. 4 is wide open, so, no resistance. I had 4 of them put into my truck. The wires were burnt and shorted the others until the problem was found. Check the plug if you do this yourself.
Jun 13, 2009 | 2005 Chevrolet Colorado
Ac blows hot
That sounds like the Blend Door Actulator has decided to go loopy. I heard of people turning it to hot and getting cold, Normally when this bit goes it makes a click click noise
Jan 20, 2009 | 2000 Lincoln Navigator
Fan Stops blowing air
Isthis a window unit? It sounds like it. There could be a problem with your fan switch or the fan motor itself? Multi-speed motors can lose one speed at a time. It really sounds like the fan motor is bad. If the compressor starts in the cool mode, and the fan doesn't, the fan motor could be locked up. See, if you can spin the motor by hand? If you can, then something is bad within the motor. Now, if the motor has a capacitor, check for a loose or burned wire. Good luck.
May 18, 2008 | Maytag Heating & Cooling
Heating & Cooling Logo
134 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
