Question about Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer
Front of washer shows something inside the plastic on outside
Looks like condensed soap between front of washer and plastic front seal. not the seal on the inside of washer
    President:
  • 1,273 Answers
It may just be spilled soap/softener the escapes from the tray when you load the dispenser. Happens here regularly. We just wipe it down from time to time.
Hope this helped. --W/D--
Posted on Jul 26, 2009
Why and how to get rid of smell on clothes with a kenmore He2 front load washer
Hi. inside the door seal is a lip that will grow mold or some kind of soap scum that turns black. pull back the edge of the door seal and wipe out with spray bleach ( wear gloves ). Leave the door open a little when you are done using it and that will help to let it dry inside.
Good luck
Aug 24, 2014 | Kenmore HE2 Plus Front Load Washer
I have a build up of mildew on the rubber seal inside the washer door-I realized too late the door has to be left open when not in use. Now the problem is how to get rid of the build up-I've tried...
Once a month, you should put a cup of bleach, white vinegar, or washer magic in your washer and run it on a hot cycle with no clothes in the washer. This will help get rid of mildew, the odor, and extra soap. The only way to get rid of the spots on your seal is to replace the seal. Make sure that you are using HE detergent and only about 2-3 Tablespoons. If you use too much soap the pump cant pump it all out and the soap will stick to the outside of the stainless steel tub. Then it will eventually get into your bearing and destroy them. After your bearings are shot, the washer will sound like a freight train when it goes into the spin cycle. Then its time for a new washer because the only way to fix the bearings is to rebuild your washer.
Jul 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The soap dispenser door will not open. How do I remove the top of the washer to access the soap dispenser? I know that the blue plastic piece for the fabric softener lifts up when I try to pull open the...
To remove top: Remove the bottom screw from the plastic clips on back of the washers top. next, stand in front of machine and, using the palms of your hands, sharply push the top back about 2 inches, allowin you to lift the top off.
Dispenser issue: you may have to drill a small hole in the plastic top of the dispenser to allow you to push the offending part down while pulling on the drawer. seal the hole with silicone or foil tape.
Feb 20, 2011 | LG WM-2277HW Front Load Washer
Fabric conditioner section in draw always full with water after cycle has finished
Detergent drawer is clogged with soap. to remove look for small plastic clip on the inside above the detergent drawer which needs to be released. Remove detergent drawer unit and wash thoroughly under running water, or bucket. Replace and problem should be solved until it gets clogged again.
Jan 15, 2011 | Bosch Classixx WFC 2465 Front Load Washer
Water is coming out of the soap dispenser, what do
We had water pour out of the dispenser of our Kenmore HE2 washer. hot water helped us for one load then i realize that a trapped rag was the problem We were actually able to pull the face cloth out of the intake tube without taking everything apart!
opened the washer door and feel around inside the rubber seals to find where the intake tube connects to the drum (upper-left side). felt a small bit of cloth sticking out of the tube and were able to slowly work it out by pulling back and forth. and pulled it completely out thats all it was try this
Oct 05, 2009 | Kenmore HE2 Plus Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
I need to change the door seal on a Hotpoint Aquarius WMA50
Basic diy tools should be ok. Take out lid screws behind plastic caps on edge(will be stars but small flat will do it).Lift front of lid and push back to remove.Remove kick plate and take out screws behind it.Remove band holding front end of seal and detach seal from rim of opening. Remove screws holding door lock and push lock through. Remove soap drawer & take out screws behind it.Carefully bring panel forward & slide to right to remove(Take care here with board &wiring)Remove screws holding front panel & lift front panel & remove it.Remove band from seal and your there.Note locating slot on seal. If possible get an extra pair of hands to hold panel with board to avoid damage.
Nov 16, 2008 | Hotpoint WMA50 Front Load Washer
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Wf860 door seal
un-plug the washer take the lid off now open the door undue the clasp that goes around the rim of the door seal on the outside of the washer (look carefully) once done the door seal should push into the washer now if u look into the washer from the top at the front though u will see a another clasp going around the door seal on the inside of the washer this is a screw un-screw it once done then the door seal should pull out repeat backwards to replace it m8
Apr 27, 2008 | Hotpoint Ultima WF860 Front Load Washer
GE front loader washer soap inside door
You can try using soap powders for 'front loading' machines......
Mar 03, 2008 | GE WSXH208A Front Load Washer
Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer Logo
102 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
