Question about Brother Office Equipment & Supplies
HL-2170W printer cartridge removal
I have an HL-2170W printer and am replacing the ink cartridge for the first time. Even though I push down the green button it doesn't pop out
SOURCE: Error Light on Brother HL-2170W
Do not try to depress the green lever, since you need to remove the cartridge AND its base altogether. Just grab the front middle part of the assembly, pull it out slowly and steadily. You may need to apply extra force in doing so as it does take some effort to disengage the cartridge assemly from its seated position.
After the cartridge is removed, you may find some jamed paper inside. simply remove it and the printer should work again.
You may email me at stevenjoy@gmail.com should you have further questions.
Posted on May 21, 2009
  • 4088 Answers
SOURCE: I replaced my toner on a HL-2170W with a brand new
Remove toner cartridge and tip end to end several times. Replace and retry. If still in trouble, take cartridge back to dealer for replacement.
Posted on Jul 12, 2009
  • 12 Answers
SOURCE: I want to take out the toner cartridge
Please go to:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002308/cv_hl2140_usaeng_usr_d.pdf
and download the user manual in PDF format - it gives directions and images of how to remove and install your toner
Posted on Jul 23, 2009
pineworks
  • 4041 Answers
SOURCE: single sheet jammed--cant remove
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 25, 2010
funkyagain
  • 24 Answers
SOURCE: My Brother HL-2170W only gets about 300 pages per
It is perfectly safe to cover the sensors on either side of the cartridge. What works best is to cover it with a piece of black electrical tape. The cartridge is set up so that when you put it in the printer, the printer shines a laser from one end of the cartridge to the other. This laser reads the toner level. If you cover both sides up with tape, it tricks the printer into thinking the cartridge is full of toner.
Hope this helps! :)
Posted on Apr 30, 2010
How to remove the ink cartridge
open the lid, lift the lock lever, take out the toner
Feb 23, 2011 | Brother HL-2170W Laser Printer
Hey, this is the first time I am changing the ink cartridge but it doesn't want to come out, even after I press down on the green button. Why? Anyone know?
First open the front cover, you have to pull on the handel in the middle of cartidge with some force to take out of machine. You can put it down on a table, then press the green button to remove the grey toner cartridge out of the black drum unit. Then put new toner in drum unit and put back into machine
Apr 09, 2010 | Brother HL-2170W Laser Printer
I can't get the cartridge out of the Brother HL-2170W. I've looked at the instructions, and the troubleshooting stuff, but can not see how to fix it.
Pull open the front door pull the drum/toner cartridge out press the green button on the left side of the drum and take the toner out of the drum install the new toner cart. and put back in the machine close the door print steven 818-888-0006
Mar 09, 2010 | Brother HL-2170W Laser Printer
Single sheet jammed--cant remove hl-2170w
Hello there
Nov 30, 2009 | Brother HL-2170W Laser Printer
Cannot remove toner cartridge from Brother HL 2170W
Had the same thing happen to me today. When you open the door to pull out the cartridge, there is an arm (less than an inch away from the green tab) on the printer which should connect to the door. When you open the door it retracts a wheel which releases the toner cartridge/drum assembly. This had become disconnected from the door.
Oct 03, 2009 | Brother HL-2170W Laser Printer
I replaced my toner on a HL-2170W with a brand new cartridge and after about 20 pages, the toner light came on and nothing prints.
Jul 11, 2009 | Office Equipment & Supplies
I want to take out the toner cartridge. The cartridge came with some paper to the right that i didn't remove, should I have to remove it. The printer doesn't work and I have a 10 inches USB cable from the...
Please go to:
Jul 04, 2009 | Brother HL-2170W Laser Printer
May 12, 2009 | Brother HL-2040 Laser Printer
No B/W print while black cartridge is full.
Your printer and its software will let you know when an ink cartridge is low or expended.
If an ink cartridge is low or expended, you see a message on the Epson Stylus CX8400 LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement.
NOTE:
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the steps below to replace one or more ink cartridges that are low on ink, expended, or too old:
1. Turn on the printer.
If you're replacing a cartridge before you see a message on the LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
2. Open the scanner.
3. Open the cartridge cover.
4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.)
6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge.
7. Remove the yellow tape from the bottom of the cartridge.
CAUTION:
Do not remove any other labels or seals, or ink will leak.
8. Insert the new cartridge into the holder and push it down until it clicks into place.
9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place.
10. Close the scanner.
11. Press OK to begin charging the ink. This takes about 2 minutes.
When you see a completion message on the LCD display screen, ink charging is finished.
CAUTION:
Never turn off the printer while ink is charging or you'll waste ink. If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Feb 02, 2009 | Epson CX8400 All-In-One InkJet Printer
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
