Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Clicking sound and warm temps
My fridge and freezer both are warm and when I plug the fridge in I hear an occasional clicking sound. The fan works but nothing gets cold.
    Problem Solver:
  • 19 Answers
Sounds like the compressor is frozen and won;t turn. a slight chance that it starter relay is bad, you will need to get a repairman to check it out.
Posted on Jul 26, 2009
GE Profile Refrigerator PSS26SGPSS stopped cooling on both fridge and freezer side. Temp controls show current temp (now 78), but when I set for lower temp, nothing happens. Hear small fan running, but...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 01, 2011 | Refrigerators
Hiya,i have a hotpoint fridge freezer ffa91 and the fridge is no longer getting cold.The compressor seems is hot but cant hear the normal noises coming from the fridge.The digital display shows an arrow...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 12, 2011 | Hotpoint Refrigerators
Left the fridge door slightly open last night and fridge turned off. How do I turn it back on? Freezer is fine
4. Wait one hour.
let me know if this works.
Feb 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
MY FRIDGE FREEZER KEEPS TRIPPING OFF AND COOLING DOWN
Replace the overload/relay . This is the piece plugged onto the side of the compressor , with 2 or 3 wires going to it . This is if you are hearing an occasional " click " . It is easily replaceable .
If you do not hear a "click" , tap on the thermostat ( knob that adjusts the temp ) , and see if the freezer fan comes on . If so , then replace the thermostat .
Nov 08, 2009 | Refrigerators
My fridge clicking, buzzing and then clicking back off. Inside it was starting to warm up and was starting to leak water onto the floor. Today someone came out and replaced the relay. After 4 hours the...
Hello, no if the compressor is still running and you are not hearing the click you should be ok. It will take approx 8-10 hours for it to get to normal temp. The frost you mention on the freezer panel could be a problem with the defrost system. I would leave it over night and check it tomorrow. If there is a major ice build up comment back and i will assist you further. Mike
Oct 19, 2009 | Maytag Refrigerators
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
Fridge/freezer warm, water puddling underneath
Hi, clicking sound from compressor, means compressor not running (working) compressor overlay relay is what making that clicking sound, possible your compressor have a hard start, you can purchase compressor ( hard start kit ) from appliance store, your fans could be working, but compressor short cycling, you said fan not working? which one inside of ref, or one near to compressor, check fan, remove 2 wires from fan terminal, use ohm tester, place tester lead one on each fan terminal, if you get a beep sound (continuity) fan is o/k, if not, fan burnt out, replace fan, now if compressor is good, fans are good, then check or replace, defrost timer, but before doing any repairs, unplug ref, excessive water is because ref defrosting, because there's no refrigeration, remove your produce, leave ref. off for about an hour, then replug it, let it work for about another hour, then check to see if temp. dropping (colder) maybe you experiencing, low voltage, let me know what happened, then i can tell you exactly, what's the problem. good luck.
Aug 11, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Compressor not coming on,temp is warm in freezer/fridge
You have a defective start relay on the compressor. That is your clicking sound. The overload relay is disengaging when you hear the click.
Replace the compressor start relay.
Jul 07, 2009 | Frigidaire Refrigerators
The freezer side is thawing and I am hearing a clicking noise.
the compressor should not be clicking sounds like u may have compressors issues if a maytag there is a recall right now on certain models call your local maytag servicers
Mar 18, 2009 | Refrigerators
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
326 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
