There is no filter on your dishwasher . If you are having a problem with it not draining than you will have to remove the drain line from the bottom of the pump.After doing this remove the hard line with a set of pliers. inside the hard line you find a diaphragm which is probably clogged up with rice or corn, remove debris and resemble. Before doing this try and remove most of the water by hand or a shop vac works best.
water from my disposal backs up into my hotpoint ($300-model) dishwasher. The dishwasher works fine...
(More)
water from my disposal backs up into my hotpoint ($300-model) dishwasher. The dishwasher works fine otherwise. Is there a one way valve in the diswasher that is suppose to prevent reverse flow and/or is there other dishwasher motor problems which could cause this. Actually the Hotpoint Model number is HDA3600N00BB but this website did not recognize that model number so I put in the closest model number closest to mine.
Leaking at bottom of front door with suds and water coming out. Cannot find the model number. Seals...
(More)
Leaking at bottom of front door with suds and water coming out. Cannot find the model number. Seals on door (3 sides) are fine. Cannot see a seal for under the door.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
