Question about Cycling
Shimano 70gs rear derailleur won't shift. The thumb levers move but don't engage. Can I fix it or will it have to be replaced.
  • 1 more comment
  • soccraig Jul 26, 2009
    Yes, the cable is still attached. The thumb levers move freely and don't engage yet the cable appears to be attached at both ends. I can't see how to remove the cover on the levers to see what's going on inside.
    I don't believe it's a cable adjustment issue. When I operate the lever the cable is not moved at all. It's like the levers don't engage at all. They went from working to not working all at once. No resistance in moving the levers at all.
I just had the same problem with my wife's old bike. After removing the cover (as explained in answer #2), I saw that the pawl (the part that engages the ratchet)was stuck in the open position because the grease had dried up. A shot of pbblaster (or WD40) freed it up and everything is now working fine.
Posted on Mar 20, 2010
Loosen the cable from rear remove philips screw from front control, push the cable so that the stop pokes out beneath plastic cowling pry cowling off. There's a plastic clockwork gear that trips the handle... the gear is probably broken...
Posted on Jan 07, 2010
  • 636 Answers
Is the cable still attached ? have you tried adjusting the cable?
Posted on Jul 26, 2009
  • mike fuson Jul 26, 2009
    Is there a jacking screw around the cable for take up? try adjusting that.
Why cant I find any information on my Shimano Tourney RD-TY10 rear derailleur?
Because it's been out of production for some time. There's no useful info to be had anyway. It is adjusted the same as most any rear friction derailleur. It is not useable with indexed levers (click to shift). If you really think you need info do the following Google search: "RD-TY10 site:shimano.com" and scroll through the results.
May 05, 2017 | Shimano Cycling
Shimano alivio front derailleur doesn't shift from intermidiate chain ring to the smallest chain ring in a inclined riding
There is typically not a single cause or solution to a specific shifting problem. The most common way to resolve your problem is to let off a bit on pedal pressure as you shift. The derailleur has to move the chain sideways off the teeth, and that is more difficult when the chain is under high pressure.
Apr 17, 2017 | Shimano XT M772 Shadow 9-Speed Rear...
Bicycle rear derailleur slips back to high gear.
It is likely that Phil has an old school Shimano Eagle rear derailleur.
I recently had a very similar issue with a Suntour friction shifter and derailleur. I tried replacing the shift cable and housing with no luck. Then I was told to replace the chain. Made no difference.
Then I took a closer look at my bike's shifter. I took my old one apart and the gear teeth that were supposed to keep the shifter from moving were worn down.
New shifter took care of it for me.
Oct 22, 2012 | Cycling
My shimano ultegra left shifter is super stiff/hard to push in; what is going on?
Try flushing out the shifter(s) with WD-40, use plenty. The next step will be replacing the shift cables and cable housings.
  • Take the bicycle in an area free of cars and obstacles, such as an open parking lot. Concentration is required when learning to use Ultegra shifters or any other type of bicycle shifter.
  • 2 Mount the bicycle and rest both hands on the proper Ultegra hand control. The left-hand control operates the front derailleur. The right-hand control operates the rear derailleur.
  • 3 Start pedaling, smoothly and evenly. While pedaling is crucial to propelling the bicycle forward, it is also necessary when shifting the derailleur. Pedaling forces the chain to rotate. The chain must rotate before it can transfer to another gear.
  • 4 Push the outside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a smaller rear gear.
  • 5 Push the inside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a larger rear gear.
Rear Ultegra Derailleur Control
  • 1 Push the outside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to larger front gear.
  • 2 Push the inside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to a smaller front gear.
  • 3 Use the front and rear Ultregra hand controls interchangeably. For small changes in gearing, using the rear control. For larger changes, choose the front control. A smaller gear causes the bicycle to travel a shorter distance per pedal stroke but also requires less energy to use. A larger gear requires greater effort but in turn causes the bicycle to travel farther per pedal stroke.
Oct 25, 2011 | Cycling
Shimano STX (combo brake and shifter) rear shifter does nothing up or down. Shifters move but do not engage the derailleur. The cable is tight and obviously not broken. Is the shifter broken or can...
You can't have end-to-end intact cable movement and NOT move the derailleur unless it is NOT tight to begin with. Look closer.
You need to figure out at which end the problem lies.
You can elevate the rear wheel (or hang the bike by the tip of the seat on a low branch) and pedaling it forward with your hand you can grab the bare exposed cable somewhere in its routing (usually along the down tube) and pull sideways on it (away from the bike) to see if the derailleur moves as expected when the cable REALLY moves. Then you can decide if the shifter is or is not controlling the cable.
Everything is replaceable as required.
Adjustments: http://www.parktool.com/blog/repair-help/categories/derailleur-systems
or use a search engine "how to...." for videos.
Jul 09, 2011 | Shimano Cycling
I have an Ultegra RD6600 and CS5600 (12/25T) on my new Look bike. I'd like to put a CS6700 11/28T on it for better gearing for the steep climbs around here. Apparently the CS6700 11/28T required the...
Derailleurs -
The RD6600 will only handle a 27T gear so no to 11/28.
The RD6700 will handle the 28T gear so yes to 11/28
Shiftlever -
The ST6600 will work fine with the RD6700.
The ST7900 should only be used with other 7900 products (Dura-ace for Dura-ace) it will work but not as nice.
There is no need to change your shiftlevers.
The ST7900 is almost fully compatible, in that any Shimano Derailleur will work with any Shimano Shift lever, However the ST7900 has a slightly different shifting pattern and the shift levers should only be used with other 7900 products to get the best performance.
Side note - If you are using standard cranks now, you could keep your shifting in tact and change your cranks to compacts and get lower gear ratios than moving to the 28T for a similar price to Rear derailleur/ cassette and chain plus labor. This is a common change in my shop.
Apr 07, 2011 | Shimano Ultegra CS-6700
Unable to select bottom gear shimano 100gs
Here is a link to a tech sheet for a Shimano Deore rear derailleur. It is not your exact one, but all Shimano derailleurs are more or less the same. Make sure you have thoroughly cleaned your drivetrain with a degreaser (like Simple Green) and a brush to clear all grease and debris before making adjustments. The second step is to shift into your highest gear (the smalles cog) and then release the cable in the derailleur, pull taut and retighten it. Check again to make sure you can not get into low gear, because it may have been a problem with cable tension, which you just fixed. If it still does not, then adjust the "L" setting on the derailleur so that the jockey wheel on the derailleur will move just ever so slightly past the last cog on the cassette when the shifter is fully engaged.
Hope this helps,
matt
Oct 08, 2009 | Shimano Cycling
Deore dx shifter stops working
had the same problem, didn't use my bike for longer period. open the shift lever carefully and try something like caramba. worked for me.
sebastian
Sep 07, 2009 | Shimano Deore Xt Thumb Shifters 7...
I had bought a Titan Glacier unisex 21 speed middle gear will not
Here is link that might help:http://www.parktool.com/repair/byregion.asp?catid=53. Also sight from back to front along the chain. The cage of the front derailleur should be parallel to the chain along its length in all three positions. Hope this helps.
Aug 16, 2009 | Cycling
Shimano 105. Front derailleur won't shift down
It sounds like you could have two different problems. Your derailleur has become contaminated or your shifter may need to be lubed. Either way, the likely solution is the same. The best solution to get the derailleur operating again is to spray it with GT-85 or PB blaster and manually move in back and furth until it is working again. The same goes for the 105 shifter, spray GT-85 inside the shifter by compressing the brake lever and spraying towards the head of the shift cable. This will solve a non-functioning shifter many times.
The only other problem that fits is the limit screws could be wrong or the deraileur is in the wrong position. This would not be the case unless someone adjusted your derailleur before the ride you started have that problem. Or if the derailleur has moved. Both of which require the derailleur to be fully readjusted.
Hope this helps. Thank you
Jul 15, 2009 | Shimano 105 Triple Braze On Front...
Cycling Logo
2,533 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
