Question about Refrigerators
My top-freezer refrig. stopped getting cold, then shut off completely. The circut-breaker was popped open. Cannot reset. Applicance is 27 years old.
    Problem Solver:
  • 19 Answers
Probably the compressor is shot. get a new one.
Posted on Jul 26, 2009
Frigidare refrig. It seems like Freezer still working but not refrig. Temp is now 56 in refrig part. Refrig is not even 2 years old. Fan seemed to be working in refrig earlier but now not at all.
check the damper vent door between the two compartments to make sure its open to let the cold air in from the freezer then make sure the evaporator fan is operating to help push air thru this door,sometimes these doors freeze shut or if its a motor driven vent door the motor could be bad too
Jan 01, 2011 | Refrigerators
After emptying the ice bin on 2 year old side frigidaire, the freezer is OK, but the fresh food side has stopped cooling. Any ideas?
check that the fan in the freezer is running,it circulates the cold air,if it isclose freezer door,open refrig. door lookto the upper left you will see where the cold air enters the refrig compartment and should fill air coming thruough vent this is a motorized unit and they sometimes fail,also check the return air hole located at bottomof refrig.sometimes get blocked by plastic bags etc
Jan 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Side by Side Refrig./Freezer ices up and shuts off
Good day,
You said it was iced up. That is an indication the defrost system is not working. The thermostat (round Disk??) if it popped out is probably due to swelling. Replace it.
Since the machine is empty, unplug and leave the doors open for 24 hours.
1. Air sensing thermometers will rise rapidly when the door is open. Not a trusted method.
2. The compressor will not run because you open the door. there is a time delay for refrigerator thermostats to react.
3. Leaving it unplugged with the doors open will guarantee that hidden ice in supply and return chutes has completely melted. IMPORTANT.
Below is a good tutorial on defrost systems.
Hope this helps , but if you need to post back please include make,style and complete model number.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa and
please rate me.
Jack.
Jan 06, 2010 | Refrigerators
I have a profile refrigerator PDS20SCPARSS, SN TF047061. If youopen the door alot ( 4 kids) te refrigerator temp goes all the way to 60deg and the freezer goes to -30. If you don't open the door at all the...
If this is struggling to maintain temperature like this, either the system is low on gas (motor running all the time) or the fan has stopped which you should be able to hear. Make sure that the fan is not just jammed.also check the return air vent in the fridge as if this gets stuck with a spillage ie O.J. etc, the fridge cannot get air from the freezer and the freezer runs continually (-30) but the thermostat never cuts out in the fridge. Last idea most likely.
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
Shuts down, interior lite on tho, plug back in and works - stops
You have a bad thermostat ( the piece where you adjust the coldness of the refrig ) . Once it gets to temp and shuts off , it will not tell the system to start again . Next time not running , tap on the t-stat . If it starts , this tells you the thermostat is bad .
Aug 25, 2009 | Avanti 651WT Top Freezer Refrigerator
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
All of a sudden stopped getting cold in the fridge portion, freezer is fine
If you completely defrost the freezer and restart the unit and it doesn't get cold in the refrig portion it could be the internal fan that moves cold air from the freezer to the frig area if it does get cold after an hour or so then it is probably the defrost coil needs replacing. I am not familar with your exact model but this senario applies to many different units.
Apr 18, 2009 | Refrigerators
No cooling in refrig, botton freezer forming too much ice
let me know I can help you get it going again..
Sep 01, 2008 | Amana Refrigerators
New Refrigerator Past Warantee Not staying cold
is the fan in the freezer running? if not then the air cant circulate and nothing will cool properly. if is running, is there frost build up on the inside back wall of the freezer? if so you have a defrost problem. if no frost on the back and the fan is running, remove the back panel inside the freezer and make sure all of the silver coils have light frost on them. if only part of them are frosted get out your manual and look at the warranty section. then seal system may have a 5 year warranty. if it does then call sear for warranty service. if the coils only have partial frost and its not under a 5 year warranty buy a new frig. because repair will cost more than its worth
Nov 26, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
