Question about Dell Inspiron 6000 Notebook
Ok when i start my note book the lock with number9 in the center stays on .it never has befor two days ago
    Problem Solver:
  • 58 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
54
Posted on Jul 26, 2009
I have a used 2001 malibu it was running ok but one morning I go to start it and it wouldn't start. I changed the ignition coil packs, ignition module, and the fuel pump and it's still not starting? ...
Your vehicle has whats called pass-lock II, it is an anti-theft setup. There is a procedure that you can do to reset the pass-lock system. Try these steps and see if it helps. Please let me know if it does or does not work and I will help you to further diagnose and repair the problem.
Step 1 - Attempt to start the vehicle. It will crank, but not run. The security light will be flashing on and off. Leave the key in the 'run' position for exactly 10 minutes, then the security light will stay solid or go off.
Step 2 - Turn the key to the 'off' position for 10 seconds. Attempt to start the vehicle. Some vehicles will run at this point, although many will require you repeat repeat Step 1 two more times. Make sure turn the key to the 'off' position for 10 seconds before each 10 minute cycle.
Step 3 - The vehicle is now ready to relearn the proper code. Turn the key 'off' for 10 seconds and then 'crank' the vehicle. It should be running now. The security light might stay on solid for several minutes afterwards, depending on your system.
Mar 24, 2015 | 2001 Chevrolet Malibu
About a week ago, having switched on and set off, all the brake warning lights stayed on, that is the ABS, TCS, TCS OFF and Brake System Warning lights. The brakes continued to work OK with no extra travel...
abs=anti-lock brake system/ tcs=traction control system ==sounds like you have a problem with ur abs possible bad sensor or a wiring connection problem when abs shuts down [trouble light] your brakes will work normal but if u stomp or brake hard the brakes will lock up skid and the tcs doesnt affect brakes but if u accelerate hard tires will spin lose traction check the wiring and connections to the sensors sometimes debris hits the wire and loosens the connection if looks ok and light is on have car scanned for the trouble code most auto stores such as auto zone/advanced auto offer this service for free the code will what and where the problem is so repair can be made
Jul 18, 2010 | 2000 Mazda 626
Problem with texting
for sending text messages :
1. call to your network operator customer care
2. request the message center number...
3.note it down
4. go to message settings>message center number
5. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Jul 11, 2010 | Motorola Mobility TracFone® V170 Cellular...
My 2003 g35 infiniti won't start oil low
I really doubt if your motor siezed up while sitting there. But your battery could have gone dead, or your stater may have locked up, or a battery cable is loose or dirty.
May 18, 2009 | 2005 Infiniti G35
Replace the window motor power window bolts and rivets
Take the panel off the door and take a punch and drive the pins out of the center of the rivets. Then drill out the rivets.( easy with the center pins out) Take out the assembly. Note remove the window before you start anything. 2 X 8MM bolts clamp the bottom of the glass. When down the most of the way the window will lift right out.
Replace the assembly and either rivet back in or use bolts and locking nuts. ( Loc Tight is recommended if you are not sure the nuts will stay locked. replace the window and you are good to go.
This should take about 1 hour from start to finish.
Apr 20, 2009 | 2003 Chevrolet Cavalier
IPod nano (4th generation).
ok stay with me here first turn the lock on and then off, next push and hold the menu and the center buttons down AT THE SAME TIME for at least 30 seconds then see what happens, this is how you reset this player.
Mar 21, 2009 | Apple iPod nano
Affinity LTF7000ES door not staying locked
unplug the washer and wait 5 minutes before plugging it in again!
this resets the system. If this does not work then you may have a faulty door lock, latch, or switch!
An need hands on service on location
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 31, 2008 | Frigidaire Affinity ATF7000E Front Load...
GE SideBySide Ref GSS25VGMD WW
if temps are ok, i honestly don't think you have a problem
Jun 04, 2008 | GE GSS20IEP Side by Side Refrigerator
Dell Inspiron 6000 Notebook Logo
44 people viewed this question
Alun Cox
