Question about Whirlpool LSB6200KQ Top Load Washer
Washing machince Washing machibne does not drain
  • 2 more comments
  • Anonymous Mar 11, 2008
    The high spin cycle is supposed to drain all the water out,but I have to reset the high spin cycle about 6-8 times after washing a load of clothes or towels on the extra large setting load size.
    my whirlpool will not drain all the water out on the high spin.I still have to reset the high spin about 6-8 times after the washer is done with a load.I end up with about 12-14 gallons of water after resetting the high spin so many times.
  • Anonymous Jul 06, 2008
    Machine goes thru wash cycle fine just will not spin at all
  • Anonymous Nov 07, 2008
    Roper name brand
Make sure the drain hose isn't kinked at the bottom rear, and the hose is freely placed in the drain. if kinked, will cause the pump not to work, and will kick the spin into low.
Posted on Mar 23, 2008
  • 351 Answers
Blocked pump or broken lid switch.
Posted on Mar 10, 2008
How do I fix a Temperator sensor on a Samsung WA5471AB washing machince
usually that happens when not a trained repair person
May 25, 2015 | Washing Machines
How do i change a belt on 90 series kenmore washing machince
there is no belt only a drive coupler can get at any local appliance store 11_4_2013_8_30_04_pm.jpg
Nov 03, 2013 | Washing Machines
I switch on the machince, but on wash mode, machine drains the water? I didn't find solution for the same. Pls help
Make sure the drain hose from the back of the machine goes up to the drain line. The end of the drainshould go up the height of the washer to keep the water from siphoning out.
Hope this helps.
Nov 02, 2011 | LG WM-2277HW Front Load Washer
I have an Indesit WIXL123 washing machine that wont drain! Have checked all pipes, no blockage, have replaced pump but it still refuses to work! Any ideas?
Since I have never physically worked on a Indesit, I can only tell you what a normal washing machince diagnosis would be: Drain pump is not functioning. Possibly something clogging the intake (count you socks) or just stopped working.
My supplier does not have Indesit parts so can't give you the part number for the drain pump.
Oct 03, 2011 | Indesit W 123 Front Load Washer
Washing machince fills with water and once full it it pumps the water right out.
You have a problem with the programmer of the machine. It start the pump, instead to command to start the washing program
Mar 07, 2011 | GE WSXH208A Front Load Washer
My machince is not filling up a the way it just stops
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Sep 18, 2010 | Washing Machines
I have a fisher & paykel ecosmart washer no water
Please make sure that your water supply lines are properly connected and turned on. Also, there are typically small filters at the end of the hoses where they connect to the washer. Check those and clean them if necessary. Since the hoses will be disconnected at that time, flush the lines by running the water into a nearby drain or bucket.
Hope this helps! Rate my solution!
Jan 05, 2010 | Washing Machines
The hotpoint ultima washing machince puts dark streaks of dirt on clothes
use enough detergent, and make sure the seals on the tub are good. Otherwise a new unit is in order.
Oct 05, 2009 | Washing Machines
Whirlpool LSB6200KQ Top Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal De
