Question about Maytag EPIC MFW9700S Front Load Washer
Front Load Washing Machine
I currently have a Kenmore He3 and don't like it at all. I now have an F2 error message and a smell while the clothes are washing. Possible drain clog?
The dryer doesn't dry well either.
I'm considering just getting a new front load washer - what is the recommended way to go - Whirlpool, GE, Maytag??
    President:
  • 1,273 Answers
Yes, probably a slow drain. F2 can indicate a long drain time. Press pause/cancel twice to clear. Disconnect the power to your washer, and clean the strainer. It is located behind the kick panel, between the drum and the pump. Remove the debris and clean. Caution, you will get water! Have something ready to catch it. Reassemble. Put the washer on the hottest setting available and run an empty, extended load with bleach. It may be necessary to do it more than once, but perservere, you'll get it. Run a last, empty load with just plain water, to flush the remainder out. This should do it.
Best regards, --W/D--. Please feel free to rate this solution!
Posted on Jul 26, 2009
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
My kenmore HE3 front load washer will not drain or open door
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Will you please replace my he3 washer? It smells,it molds,and stains my clothes.I am very disappointed in this machine.Maybe you could send someone out to my house so I can do their laundry and their...
if you haven't tried AFFRESH it works the best on this washer and after a few loads with Affresh in it it should smell fine but you will have to use a cleaner for now on
Sep 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F2 error code on my Kenmore Elite HE3 washer
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE HE3 WASHER
2 things you may try if you haven't already ..let washer fill with hot water ..pause and open door pour in about 2 cups chlorine bleach before starting back up..with rag soaked in bleach/water clean inside front door boot ..be sure to roll boot toward front and clean out accumilation under it wash as much as possible off door seal..allow to finish cycle (normal wash should be fine)..may also try removing lower panel remove pump acess plug and clean pump out thoroughly..you are not alone ALL front washer have same issue and if some sort of routine cleaning isn't done problem reoccurs also leaving door slightly open between usues will help ..by the way that is a german made washer
Sep 12, 2008 | Kenmore Elite 45986 Front Load Washer
Mold & Smelly in Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore Elite He3 sounds like it has water in the tub after washing AND smells of MOLD?
there is always some water left inside the machine and that is probably what you are hearing are you using liquid detergent? if so this is almost certainly the cause of the smell. liquid detergent leaves a nasty slime inside thge machine and smells like drains. put on a boil wash with no clothes and revert to using powder detergent
Apr 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
206 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
