Question about Toshiba 32AF62 32" TV
I was watching my Toshiba 32AF62 tv and the screen went blank. The LED power light blinks on and off but nothing beyond that happens. Any ideas as to what the issue may be?
  • tony_pelke Jul 27, 2009
    I have already tried this and nothing happened. Any other ideas?
    President:
  • 2,187 Answers
Hi There,
Normally this happens when the TV system detected a problem internally. The problem is with this one there are a lot of internal components that may have gone out. If you have tried turning off the TV overnight, then the problem may be with the hardware or the internal components. This could have been due to a surge of electricity or heat. If you plan on doing this yourself, please check the warranty as a service center may be well suited to trouble shoot this.
You may want to inspect first the power supply, the flyback and the horizontal output amp as these are the first that usually go out. See for physical signs of burns or leaks on the capacitor and even the smell of burnt components will provide you with a clue. If you have a tester you may check the components if they have power starting the the power supply.
Posted on Jul 27, 2009
  • Toshiba Master
  • 5,807 Answers
first have to disconnect the AC plug to your main outlet, let it be for a few minutes, try 10 min
power it up
if symptoms persist, you just have a bad TV.
it is in protection state, and protecting itself from further damaged, and may not power up, till the fault is repaired and corrected.
If the unit is still in warranty give a ring on the dealer or visit the manufacturer web site.
note down the number of blinks
might have digital bd or power bd problem
hope i have helped you, thanks for using Fixya!
Posted on Jul 26, 2009
  • Rommel Cana
    Rommel Cana Jul 27, 2009
    hi,
    you have tried, unplugging the unit and turning back on for a few minutes am i right on that?
    and still the same problem.
    it is in protection
Samsung HDTV black screen no picture no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 12, 2017 | Televison & Video
Panasonic Viera tc-p65s2 - 7 blinks, won't turn on
I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The pop is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
Aug 06, 2012 | Panasonic VIERA Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power light on, no sound or picture
make sure all cables are plugged in
Jan 15, 2010 | Toshiba 32AF62 32" TV
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Power indicator light blinking
Check soldered in micro fuses...F850, F851 etc.....
1) solder jumper wires on signal board = 008,010,017,048,600
2) Check / replace STK392-110 convergence IC's with Toshiba
part # 23135090 or upgade to Hitachi part # CZ01341
Let me know....................T.
Jan 04, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba 32AF62 32" TV Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
