Question about Baby Gear
I lost the one of the buckles to the car seat when I took the cover off to watch it. Where can I buy a new one?
Walmart or toys r us should have replacements
Posted on Jul 28, 2009
Tip
Middle seat belt buckle tip for booster seats, car seats, and large humans.
In trying to fit a booster seat into my 2004 Honda CR-V, I realized that the CRV has the belt buckle in the middle of the seat. This is a big problem for someone using a child seat in the middle seat as the buckle receptacle is completely covered by the booster seat. I thought about buying an extender but realized it wouldn't completely solve the problem. After much thought I came to the conclusion that the buckle receptacle could be moved to a new location without compromising any safety of the belt. I first pulled the buckle receptacle all the way out and then cut the fabric to enlarge the hole from which it protrudes from the seat. Then I pushed it through the hole and back into the seat with the head pointing towards the window and outer edge of the seat. After flipping the window seat out of the way I was able to peel the fabric away from the bottom edge of the middle seat enough to reach in and retrieve the belt receptacle. It was a little tight but I was able to buckle the belt and use the seat belt to pull the receptacle through this new "hole" and VOLIA the belt receptacle is now in a better position to the side of the middle seat. You can now used a booster or car seat or put a fully grown human in this seat and buckle with ease.
on May 20, 2015 | Cars & Trucks
I took the cover off for washing. Need instructions to put back on
You should be able to download the instruction for this model from this site
Instruction Manuals
You will have to remove the buckle loop holding the harness at the back of the seat and release the straps. Once you insert these through the seat cover and back into the slot on the seat back you can lock the harness by re-inserting he buckle loops.
Aug 25, 2014 | Cosco Baby Gear
How do i disconnect seatbelt chime mitsubishi mirage
On many cars, the seat belt sensor is also used to trigger the airbag. Investigate whether this is the case on your car before doing anything drastic to your seat belt alarm.Locate the wire under the driver seat that connects to the buckle with the release button. It should be towards the rear on the right hand side, where you plug the belt into.Follow the wire to an area under the seat where you will be able to fit your hands into.Look for two wires running together. Cut through both of them and slightly separate the ends apart.Use electrical tape to cover the wire ends so they do not short out on each other or metal under the seat.Tuck the wires away from the seat brackets so they do not get tangled if you move your seat.OR>>>>
On the side of the receptacle (where you would slide the buckle into) are two non-tamper torx screws.
Remove the screws using a hollow T10 bit.Carefully remove the plastic side cover. It contains a spring loaded slide switch.Remove the small spring and slide the switch down to its lowermost position.You can double check by watching the seat belt light on the dash go out.Replace the plastic cover and screws.Store the small spring for use in the future. This way the system thinks the buckle is always in so the light and chime won't alert at all.
Jul 22, 2014 | 2014 Mitsubishi Mirage
We have a 2002 model child car seat that also has Costco on the buckle. The buckle that is to hold the child secure will not latch. Can this buckle part be replaced?
Car seats are usually only good for 5 years unless there is a label on the seat that states otherwise.  you would be better off buying a new car seat
Sep 06, 2009 | Baby Gear
Winnie the pooh graco car seat how to put the arm straps back together after washing
I had the same problem, so what I did was look at the first picture from walmart.com's page with this car seat.
http://www.walmart.com/catalog/product.do?product_id=10843110
I noticed where the straps went through the restraint systems, and remebered that I took the bottom ones out last, so I'd put them in first.
Then I threaded the straps through the buckle parts that snap to the bottom buckle, up through the buckle parts that snap together, then back through the holes in the cover and seat at whatever height your infant is. After that you secure it in the back like the sticker at the side indicates :)
I hope that's clear enough!
Jun 17, 2009 | Graco Nautilus 3-in 1 Car Seat
Seat belt
well make sure you are using the right buckle for each seat some cars have matching buckles.If this dosent work you will need to buy a new one.
Jan 11, 2009 | 2000 Chevrolet Tahoe
Cosco Buckle Broken
Bought a new car seat
Sep 26, 2008 | Cosco 02-442
Replacement part needed for Nania Go Baby Newfix Travel Easy Car Seat
you wont find a buckle you need to buy new straps safty reasons
Mar 30, 2008 | Baby Gear
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
