Question about Uniden DECT 6.0 Cordless Phone ID
I just bought a uniden phone and i charged it overnight, but the main base does not light up but the phone itself shows it is charged. should i take it back and get a new one?
    Sergeant:
  • 277 Answers
Wellcome,so far you check the phone and it indicated that it is charging you can still use it like that or you may go there and complain for the seller as well.
Posted on Jul 26, 2009
CAN NOT CLEAR WATER PROOF DECT 6.0 PHONE TO REGISTER IT SAYS TO PUT ON BASE BUT I WANT TO REGISTER ON MY OTHER UNIDEN BASE BUT PHONE WON'T FIT ON BASE
Not stating the model number of your phone makes it a bit difficult because the process is not the same on all models. I am going to deal with the cordless main base only Remove any handset from the main base cradle. Then
On the waterproof handset Press and Hold the # sign until the Registering handset option shows then release it.Then on the main base, Press and Hold the FIND hs or Find or locator button for 5 seconds ( if there is no IN USE light on the base) or until the IN USE light come on, then release it. Hold the handset near the base and it will register.
Please note the Uniden waterproof handset could be a bit tricky to register and not knowing the model makes it more difficult. and you may have to apply other methods.
May 03, 2017 | Uniden Lands Phones
Charging problem
The fact that one charges on all 3 base units rules out any problem on the base units. Sounds like the batteries on the 2 faulty handsets need to be replaced. I suggest you return it to the store, and get yuh money back, or replacement
Dec 10, 2009 | Uniden Cordless Phone
After 6 weeks, phone is dead
still warrentty time so contact ur uniden cordless phone dealer
Jul 19, 2009 | Uniden Cordless Phone
Cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Apr 25, 2009 | Uniden DECT 6.0 Cordless Phone ID
UNIDEN EXP7900 NEW BATTERY CHARGED, GREEN STATUS LIGHT ON, BUT CANNOT GET A DIAL TONE. THIS WAS AFTER THE PHONE HAD BEEN UNPLUGED FOR ABOUT 3 DAYS.
I have a Uniden DECT 6.0, 2 handset phone. I charged the batteries twice for at least 15 hours. I usually unplug the base at night and plug it back in in the morning. Both the phones lose their charge overnight. My old Uniden phone never lost its charge. Is this because the new batteries are smaller than the old ones? Are the batteries bad? I bought this phone from Ebay who said this was a brand new phone, box never opened. Thank you.
Nov 16, 2008 | Uniden Lands Phones
Uniden TRU8885-2 Restarts every time an incoming phone call, start showing the Welcome message ....
YOUR batteries are bad and not giving full current to phone.Clean charging contact and see battery gets full charge. IFthe battery indicator will show full charge due to voltage but once if you remove battery and put it again indicator will be minimum. then replace batttery.
Oct 07, 2008 | Uniden TRU8885-2 Cordless Phone
5.8 uniden phone
try putting the phone back on the main base of the phone system so the base can register it to itself again.
Sep 21, 2008 | Uniden Cordless Phone
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Uniden phone
That sounds like the battery is not charging properly. When in the charger there is enough voltage passing to power the handset, but when pulled off the charger it must rely on just the battery. I suspect you replaced your battery because you were having a problem, right? Your problem may be dirty charging contacts. Try taking a pencil eraser to your charging contacts on your handset and base. Try charging your handset again, and ensure your charge light comes on when doing so. Let it charge overnight. Hope that helps. CG
May 26, 2008 | Uniden Cordless Phone
Uniden handset doesn't work
If you replaced it with a working new battery pack. You can test it in another phone. The Battery pins on the phone board could have a poor connection which requires soldering.
Dec 19, 2007 | Uniden TRU8885 Cordless Phone
Uniden DECT 6.0 Cordless Phone ID Logo
101 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
