Question about E-Machines eMachines Monitor E15T4
My computer only displays the "eMachines" logo when turned on.
My monitor works properly, I see lights on the tower and hear the fan working. Any ideas what the problem could be?
  • 76 Answers
Hard drive failure
Posted on Jul 26, 2009
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
My emachine desktop tower will not power on
the sound you are hearing or heard could have been power surging through a powersupply unit that just blew.. hopfully it did not effect any of the other hardware..to trouble shoot this you can do one of two things..1 disconnect the 20/24 pin powerconnector from the motherboard 2 disconnect the cpu power connector 3 disconnect the 6pin power connector from the graphics card if there is one some machines have onboard video chipsets if thats the case then no worries 4 disconnect the Harddrive power 5 jump the power supply to see if you get any power from it any questions on that go to youtube and type in how to jump a power supply... or option 2 is buy a new power supply make sure its 80plus certified and replace it...i know its a lot of work but i hope this has helped you
Aug 26, 2012 | E-Machines eMachines Desktop PC
My computer will boot, I can hear the windows noises but the monitor will not come on at all. It keeps flashing. Also after a little bit the light on the tower starts flashing like the monitor does.
try to unplug and plug the cable from monitor to your pc, this is a problem of a connection. If it does not help, try some other cable which is working on another computer.
Flashing tower light is not a problem, it probably starts flashing just because of you are not doing anything on your computer, so it turns to sleep mode.
Hope this helps,
Lucas
Jul 08, 2011 | eMachines EL1210-09 PC Desktop
I have a problem with my computer emachines j4501 desktop pc windows vista home premium..after the windows logo the monitor turn blank...but the cpu is still on.... what will i do...
If you can see the windows logo screen both your computer and monitor is working, possible problem could be that the display settings are set to high that your monitor is unable to handle it. Restart computer and keep tapping F8 key. This will take you to the advanced options menu In the list of options here choose enable low resolution mode and hit enter (you can only use your keyboard to choose - use the up / down arrow key) once you enter windows low res mode change it to 800 X 600 and restart the computer Once you are in the right mode now change the display settings accordingly.
Mar 12, 2011 | E-Machines eMachines Desktop PC
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Yellow power light on HP SR1420NX
For reasons yet to be determined, your computer is not talking to your monitor.
This could be the monitor cable came loose from the tower (this is our favorite, because it is such an easy repair), or something on the motherboard (that is, anything) that is not functioning and preventing your computer from starting.
Unplug the connecting cable, and plug it back in again, making sure that it is seated properly.
Do you hear any sounds besides the fans? You should be able to hear the faint clicking of a hard drive starting up also. If you hear this, the problem is not in the computer, but in the communication to the monitor.
Good luck
tony
May 23, 2009 | HP Compaq Presario SR1420nx...
Emachine tower unresponsive
Unplug the Monitor, and attempt to reconnect a seperate monitor to test. If that monitor works properly, then the problem is your regular monitor. If you do not have another monitor, Try unplugging the power from the wall jack to the tower. Then plug into another port, the reason the computer doesn't turn on is because the power outlet may be running but at a lower voltage then what is required for the computer to run at its full potential. If theese both fail, Try opening your computer and check if anything is blown out.
Feb 07, 2009 | E-Machines eMachines Desktop PC
Tower
Hello:
Please to check and fix the following:
the ; memory, VGA connecting to the monitor, fix all cable connecting to all hardware inside the system.
the problem most likely is in the memory. please do.
if does'nt work i will give you the step by step troubleshooting of your PC.
eager to hear you soon , best regards, melnavz
Feb 20, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Monitor E15T4 Logo
107 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
