Question about Northstar Pressure Washer 3000 PSI
Engine does not start. I ran it about two weeks ago and it worked fine. I took the spark plug out and it was dry. I made sure there was gas in it. I tried some starting fluid by spraying into air intake and it start running for a short time until the starting fluid ran out. I removed the carb bowl and there was gas in it. However the inside of the bowl and the float had brown deposits and looks like rust. So I think the main jet has been clogged up with a particle. How do I clear it? Where do I get replacement parts?
  • 76 Answers
Try cleaning the carb with gumout spray and a little compressed air, be careful to reassemble the float and needle valve exactly as you found it.
Posted on Jul 26, 2009
RX 75 It won't start.....
change the spark plug. i have had 3 rx 75 that after i changed the spark plug they ran fine.
May 14, 2016 | John Deere Garden
Craftsman tractor lt2000 with 17hp Kohler won't start. Ran fine last week. Rebuilt carb, changed oil, and new plug & fuel filter month ago. Has spark and fuel. Cranks but won't fire.
Hi Mike:
It's trying to make you crazy.
I have a model YT4000 and it is a PITA to start when cold.
I pull the air filter, toss in a bit of gas to prime it, and it starts instantly.
I'd suggest that you give yours another try. 3 or 4 times of a couple of seconds each. If it doesn't go, pull a spark plug and see if it is wet or dry. Wet indicates getting gas but no spark. Dry indicates not getting gas.
While you have the plug out, check the spark... Hot & blue.
Hope this gives you some more to work with.
Jun 22, 2015 | Craftsman Garden
I have a 14sz that want run
Did you run it out of gas two weeks ago? The carburetor jet may have sucked in some dirt.
Nah, not the plug.
Aug 24, 2013 | John Deere Garden
Poulan Leaf Blower
you may need to turn the Hi screw on the carb in 1/4 of a turn. Make sure the gas and mix are fresh.
Jul 22, 2013 | Poulan Garden
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
A week ago i took my bike to get fixed at a shop it had been sitting for about 2 years the guy said it was a dirty carb and a dirty gas tank he cleaned both and the bike ran fine i rode it for 2 min. or so...
Try replacing spark plug,and check for spark if you do good,check to see if you have fuel to carb,at bottom of carb there is a float bowl screw loosen the screw and let fuel drain,tighten screw,choke and try again,sometimes when bike sits that long it may need one or two cleans,the bad gas that was in it still has varnash build up and can still clog up the jets.hope this helps.
Feb 17, 2011 | Suzuki RM 125 Motorcycles
2005 honda crf150f
i dont think its rev box.(rev box just keeps engine from reving over a certain rpm) could be bad gas or water in gas, also have you checked those valve clearances lately?? 0.003--0.004 on filler gage
May 15, 2010 | 2003 Honda CRF 150 F
24 hp briggs intek vtwin won't start
This same thing happens to me and I resolve it by taking the gas line off in front of the carb and blowing air through it.....then it will run fine. I realized I could do this when I took the air cleaner off and fed it gas manually and it ran fine....and I also had gas pumping through the fuel pump. I'm not sure of the problem....either the fuel pump is losing power or their is something blocking the carburator intermitantly
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Northstar Pressure Washer 3000 PSI Logo
260 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
