I have a z22 palm pilot and whenever I open the calendar from menu I get the year 2005 instead of 2009. When I try to set the date I can get the month and day that I want but the year always reverts to 2005. Please con tact me at 972-523-673735 or by email miriamhb@netvision.net.il Thank you in advance Miriam Halpern I need your help!!!
  • 2 more comments
  • miriamhb Jul 26, 2009
    My palm shows that the battery is charged. I use the charger which came with the palm and the icon on top shows that the palm is fully charged.
    The battery is permanently fixede inside product I am not synced with email.Someone suggested soft reset after starting recharge the recharge for 4 more hours.so far problem still exists
    Since your solution may require a pc/software guy and our guy is busy tonite we will revert to you in a day or two when he becomes available.In the meantime we will suspend interaction.Thanks,friend.Miriam's husband Shimshon
  • miriamhb Jul 28, 2009
    iT TOOK A LONG time to do it with also a chat room helping, but it was the daylight saving time problem
    President:
  • 846 Answers
Hello Miriamhb,
I'm not quiet sure what's been going on with the other "experts" you have been dealing with but the problem has nothing to do with your battery or resetting.
Problem with the Z22 is the daylight savings firmware, this will cause your pda to display the wrong date and even time. This problem was fixed in 2007 and there is a free download available to fix this. Click the following link and the instructions to fix the problem. CLICK HERE
Post back if you need any further help and Ill be happy to assist. Thank you for choosing Fixya!
Posted on Jul 26, 2009
  • Quickfx PC Repair Jul 26, 2009
    That would be fine, that is the fix so I will wait for your response after you have tried it. I would hope after you have your computer guy do it for you (as that is the correct and only fix)...that you will rate my solution giving me credit for helping you.
    Post back if you need any further assistance, thank you for choosing Fixya!
    President:
  • 3,278 Answers
The solution does not require a PC tech, unless there are tabs present on the circuit board (see Step 3) ...
You need to reset the battery.
Here are the instructions to reset the battery:
  1. Pull down on the back cover of your Palm Z22, and remove the cover from the device. Find the screws that secure the halves of the devices casing together.
  2. Loosen and remove the screws from the Z22's casing using a star-bit screwdriver.
  3. If there are tabs present on the circuit boardI have a z22 palm - 2.gif, you will need to stop immediately. Consult with a technician about removing the tabs.
  4. Find the battery. Move it out of the case so you can have better access to the power supply lead.
  5. Pull the power supply lead from the battery. Grasp the base of the plug firmly and disconnect in one smooth motion.
  6. Reconnect the plug.
  7. Replace the rear cover on the Z22.
Hope this helps.
    President:
  • 2,923 Answers
Is it synchronized with your e-mail calendar or you're just using the calendar of your PDA without synchronizing it to your e-mail?
If you're just using the calendar without synchronization, you may try performing a power cycle or soft reset on your PDA. Please follow the steps below:
1. Turn off the Palm and remove the battery out of it.
2. Leave the battery out for 5 to 10 minutes.
3. Put the battery back and turn the PDA back on.
If you get the same problem, you need to contact the manufacturer for possible firmware upgrade or repair.
If the calendar is not working correctly while synchronized with your e-mail, you have to access your e-mail first and make sure that it is properly configured. You may want to check the server path on your PDA as well and make sure that the server path is setup correctly and the server mode is set to either slow or normal.
For this case, I would advise you to contact your phone service provider or your e-mail provider for proper modification.
Have a great day!
  • 1,555 Answers
Sir, At fixya we are not allowed to directly contact the users. We can only interact via the platform provided by fixya. Whatever problem you are facing at present is because of blackberry. Anyways sorry for your inconvinience. At present situaltion your built in battery for your Palm Z22 Specs
has given way thats why you are unable to keep update. I tried everywhere but these guys are not giving out the battery on sale other than their service center. Kindly let me know how shall i provide further assistance to you. Shall i seek wendors providing battery for your. or whatever you feel like.
My Palm z22 syncs. Trying to get calendar into the handheld. After it syncs there is no info still- says no appointments today but I put a bunch.
make sure that the updates for the calendar or apointments are set the right way. You may find that it is set to let the palm overwrite the desktop and it should be the other way or to syncronyze both so they show the same thing. If the program doesn;t show this setting check on the hotsync icon (right click on it whe its running) and check the settings.
Mar 23, 2010 | Palm Z22 Handheld
I tried to sinc my palm Z22 with my new computer, but It shows that my drivers aren't installed. what's wrong??????????????
Palm as a corporation went out of business years ago, and there are no drivers for the new Microsoft Windows versions that were made AFTER Palm no longer existed! HP (Hewlett Packard) bought the Palm Operating System and has the basic the basic drivers and manuals online, however, only "other" corporations that use various PALM type devices, now support interfacing. I have listed all those that I have found on my web page, dedicated to repairing, maintaining, and interfacing the Z22, at:
kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
I do not SYNC my Palm at all, so that you will have to rely on all the USER comments that I have included.
good luck
robin dusty graves
Z22 PALM PILOT tried-sinc-palm-z22-new-computer-ngl0e1lc0ft3j10pmz4xzklk-3-0.jpg tried-sinc-palm-z22-new-computer-ngl0e1lc0ft3j10pmz4xzklk-3-1.jpg tried-sinc-palm-z22-new-computer-ngl0e1lc0ft3j10pmz4xzklk-3-3.jpg tried-sinc-palm-z22-new-computer-ngl0e1lc0ft3j10pmz4xzklk-3-6.jpg
Mar 08, 2010 | Palm Z22 Handheld
Recover lost calendar events on a Palm z22
Hi suzbt:
JOY's answer, that you try to do a SYSTEM RESTORE on your Computer to get the data back is a really good one, that I did not think of! All manual instructions, and USER instructions on doing a SYNC with the Palm Z22, REPEAT : 1/ Always have a back up of the hard data 2/ Always check all transferred DATA on a SYNC, "Even if it states 'transfer Successful'", 3/ Even, if necessary, write down the data, ...
There are a few software programs to identify FILE problems on the Z22, listed on my web page:
http://kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
and ways to recover corrupt data, but these are getting more and more difficult to find and use...
User comments on the SYNC indicate that any SYNC is a risky procedure, and backups and re-checking all data is necessary at all times.
I hope that the information on my web site comes in useful in keeping the Palm Z22 up and running!
good luck
robin dusty graves
Z22 PALM PILOT recover-lost-calendar-events-palm-z22-cdqazwk5fkdpm30unkbxcrm5-2-0.jpg recover-lost-calendar-events-palm-z22-cdqazwk5fkdpm30unkbxcrm5-2-1.jpg recover-lost-calendar-events-palm-z22-cdqazwk5fkdpm30unkbxcrm5-2-3.jpg
Sep 10, 2009 | Palm Z22 Handheld
I have a palm z22, everything on my desktop is completely erased, however I still have the calendar data on my handheld. I need to restore the calendar on my desktop for my secretary, who updates my...
Lower right corner of pc is symbol to activate synchro. Right click on it and go to custom. Check to see calendar is checked to go from palm to pc ONLY. then try restoral. If this is helpful, please post as such.
Mar 18, 2009 | Palm Z22 Handheld
The light on my palm pilot (Z22) screen is dimming.
There enlies your problem. Tungsten longevity. The display is a bulb that is dying. No adjustment. Tungsten won't touch it. It is a SEALED unit. Time to upgrade to an E2. I know alot about them too, including how to make it go internet. If you get an E2 ALL your info will cross over. If you have any questions, please create a new request, make it a premium, request it be for Just_Bobz and I can walk your through most anything you want to know. Please post this as fixya. Be talking to you soon. TY
Jan 24, 2009 | Palm Z22 Handheld
Hot sync doubles appointments
I went into the HotSync Manager and changed the settings to Desktop overwrites handheld. That did the trick!
Sep 16, 2008 | Palm Z22 Handheld
Uninstalling program from the computer?
  1. Go to Applications 650_app.gif (info).
  2. Open the Menus 650_menu.gif (info).
  3. From the App menu choose Delete.
  4. Tap the name of the application you would like to delete.
  5. Tap on the Delete button. Tap on the Yes button to confirm that you wish to delete the chosen application.
Delete programs from your Z22 by using your Z22 and not your computer
Jun 05, 2008 | Palm Z22 Handheld
Outlook calendar won't sync
no expert, but I had a problem with calander when I tryed to syn with yahoo. conduits got all messed up.
So I now use another computer. :)
Jan 30, 2008 | Palm Z22 Handheld
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
