Question about Dryers
Kenmore Dryer (Model 110.84834201) won't start after power surge
We had a power surge that caused several power strips in the house to blow and now the dryer does not function. The door light works but that's all.
1. Is there an internal fuse that could be blown?
2. If so, where is it?
3. Can I get a wiring Diagram?
Thanks,
JKG
    Sergeant:
    Champion:
  • 246 Answers
The door light works on 110 volts which is obviously ok, but the dryer works on 220 volts and it sounds like your circuit breaker might be tripped due to the power surge. Try resetting your circuit breaker by turning it completely to the off position first and then back on.
Posted on Jul 26, 2009
    Problem Solver:
  • 10 Answers
The dryer has a few fuses. I will give the best website I have found it gives diagrams and part pictures for all appliances. I have ordered from them many times and always got the right part. Go to www.repairclinic.com The fuses on the dryer are very easy to change and you can get the parts in only a day or two.
Kenmore elite sensor smart electric dryer Model 110 65066500 I have power but won't start
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Troubleshooting Why Your Dryer Won Start PartSelect com Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 24, 2014 | Kenmore Dryers
We a Kenmore Elite clothes dryer (Model # 110 70972990). Monday there was a power outage that happened while the dryer was running. Hours later when the power was back on, we tried to finish drying, but...
There is a thermal fuse. If your lint filter is on top of the machine it is in the rear of the machine behind the removable panal near the exhaust port. If the filter is in the door the fuse is behind the kick plate on the top of the blower housing they are usually white plastic. But a power outage won't blow the fuse
Oct 19, 2011 | Kenmore Dryers
My dryer will not turn but the light inside works. we had apower surge from downed wires and several items in my house wereburned out from the surge what in the dryer could have been damaged by the surge...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Kenmore Dryers
Stackable Kenmore model 110.98752. Dryer drum turns but no heat. Vent does not appear plugged since air does flow through to outlet.
With your volt ohm meter (VOM) check for 220 volts at the terminal block the cord attaches to.
If 220 is present, unplug the dryer and remove the rear panel.
With meter set to continuity check the thermostats and fuses on the heater as well as the heater coil. Remember to unplug the wires to each component to check them correctly.
You should read 120 volts from black to white and red to white for a complete circuit.
Look closely at the wires at the terminal for a burned wire.
No burned wire, open the wall outlet and inspect the wires and the female connections.
Read voltage at the wall connection for 220 volts and 120 volts from hot to neutral on both legs.
With the power disconnected you should take at least one wire off each thermostat and limit just to be sure you don't somehow get a false read.
If it runs at all and the heating element is OK then you most likely need a limit kit.
You dryer has a series of safetys. If the control thermostat fails, the filter housing gets blocked with lint, or the vent gets stopped up the heat could cause a fire. The bottom cannister thermostat limit is the lowest temp one 250F, it should shut down first if it fails then the limit mounted at the top of the cannister is set to Blow at 300F When it blows that is an indication of an external vent blockage. If the problem is from within the dryer then the fuse mounted on the blower housing will blow an the dryer won't run. The fuse is rated at 350F and is tied into the door switch. That is why the wires are smaller. They don't carry the heat load. If the duct fuse blows it is the same as if you opened the door. The dryer simply quits running.
Jul 16, 2011 | Kenmore Dryers
I have a Kenmore 110.63032102 dryer and I put a pair of sneakers in it. It shut off and now it wont even turn on. What's wrong?
Drying a pair of sneakers causes the dryer to overheat and this causes the thermal fuse to blow. The thermal fuse is wired in series with the motor circuit and if it blows, power to the motor is terminated causing the dryer not to turn on. Disconnect power then Pry the lower access panel off with a flat-head screwdriver as shown.
Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to expose the thermal fuse on the blower housing.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards. Let us know if you need further advice.
Jan 26, 2011 | Kenmore Dryers
Model ATF6000751. Replaced speed control board a month ago when final spin failed. Worked fine until yesterday. Could something else be causing the board to go bad?
Power Surges. In my area we suspect that 70 to 80% of the repairs here are caused by power surges. They happen all the time, andyou do not have to lose power to have one. They can happen when you have lightning, windstorms or beutiful sunny days. You have to have a 2000 joule surge protector or higher on your washer, refer, microwave oven, and gas stove or dryer if you have them. For your washer , gas dryer, and refer you have to have a rectangular box wall mount surge protector. You cannot have a power strip surge protector on a cord as moisture can get into it and cause electrical fires. I have seen three major fires caused by power strips behind washers. Lowes and Best Buy sell wall mounted box surge protectors with a 2150 joule rating that have 3 plugs on each side that rotate from front to the side so that you can plug your refrigerator into the side and not have the refer sit out from the wall any more. Good Luck, Appliance Specialists.
Dec 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore dryer not working
replace the thermal fuse this part is on the blower housing unit. you will see it when you take the back panel off. its about 2" long with 2 wires. white black strip on inside.
Nov 06, 2009 | Dryers
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
Won't work
unplug your microwave; remove the top under the top you will see a small white cylinder
(a ceramic fuse) it looks like a glass fuse only made of white glass replace this they are sold at radio Shack
Apr 22, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Dryers Logo
347 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
