Only half the screen displays on DVD player, Wharfedale WDP 1210
We've had the Wharfedale personal DVD player for only 18 months and now on boot-up and play, only the left half of the screen displays correctly. The right half shows just random moving noise lines, split exactly down the middle. Perhaps a display driver chip problem?
All suggestions gratefully received.
  • 1 more comment
  • PeterSpruce Jan 01, 2008
    Thanks for the suggestions Sedonix and AvioriX. Twisting the panel did have an effect: the noise signal disappeared and now there's just a static display of feint lines, but still over half the screen. The other half remains unaffected. I've taken the screen casing apart and fiddled with all the ribbon cables but there are no obvious loose connections.
    Trying the video out to a TV is a good idea.
    It is the 1210 model and I have attempted to make the connection to a TV via the yellow socket on the side but it doesn't work. If you can tell me how the external AV connection is set up, I would be grateful.
    Thanks
    Peter Walmsley
  • PeterSpruce Jan 09, 2008
    I can't yet get to the bottom of the half -screen display problem. It appears from eBay posts that this is not unusual and must therefore be a relatively common component failure, including the screen itself. Does anyone else have a clue about which component though?
    Thanks for the reply Darklord1. That's the sort of answer I expected. Yes, I understand that these companies consider the items disposble, though £140 ($280) doesn't sound that throwaway to me and I enjoy a challenge! Trying to resolder a surface mount component might be pushing it though.
    Last question then: to find the Video Output module. There's a circuit board on the back of the display inside the lid, rather than inside the body of the device. This would seem to be the most logical place to find the driver.
    The 3 largest ICs are a PVI1005a which Google tells me is a timing controller, a Philips 74HC4053D which is a mux/demux and an unbranded component (the largest) with the number AR01B VL.1.Z which I can't trace. Any further thoughts on what I should be looking for would be welcome.
    Many thanks again.
  • 2,427 Answers
Hey sorry about your problem, i waited a bit before i posted this in case some other expert might have been able to help you..
Yes you are right, the problem is a common one and it does stem from the Video Output module (ic) yes it can be replaced but these players are cheap it isnt worth the time and hassle tracking down one and then having to replace it. Mostly when this happens the item is considered disposable..Thats why it didnt work when you connected it to the television via the tv output..
If you wish to try to repair it you will have to open your player and get the ic model then google for one, or a substitue(i recomend the substitute as it is cheaper and works better than the original) or you can get it at your local electronics store...
my regards
Posted on Jan 09, 2008
  • Rishi Roshan Ali Jan 09, 2008
    Well it should be there, are there any enclosed modules? but it should be there any way it's a bugger to change it so be sure you want to before you actually go through the trouble to google all the ics you find... BTW IT SHOULD BE LABELED ON THE BOARD
  • 579 Answers
Either a problem with the driver or the display panel. Not much you can do about the driver, but more likely its the panel.
Try squeezing the display panel or gently twist it etc. to see if that has any affect on restoring any bad contacts etc.
Posted on Jan 01, 2008
  • 689 Answers
Is your DVD Player's model WDP1210 or WDP3397B.
If you are using one of these model I will strongly recommend to use AV output to a TV instead of using its LCD screen. If you get full picture at TV, You will isolate the matter that LCD module has problem. If so you can check with a local repair center. If you have any help regarding TV connection via external AV cable please post a follow up message
Hope it will help
Happy New Year
Codes for a wharfedale wdp 1210 mobile dvd player for a all for one remote
0723 1835 0134 2382 These 4 are missing from your tried list and are also codes for warfedale DVD Players for the simpleset so hopefully one of them will work for you. after trying these 5 thats all of the codes supplied via One4all.
Mar 13, 2014 | Televison & Video
Replacing a wharfedale dvd player battery
Try www.ebay.com type make and model of player and scroll through the list, also check www.whafedale.com contact customer support and the technical department.
Jun 15, 2012 | Wharfedale Televison & Video
Problem with dvd recorder
check *********** board memory ic or change.
May 31, 2012 | Wharfedale DVD-M3 DVD Player
Can I order a rechargeable battery for wdp-1210
you can order a charger here: Amazon Should work on a flight ;) But no battery around anywhere...
Aug 23, 2010 | Audio Players & Recorders
When a disc is loaded into a dvd player it displays no disc
hi alfredmuyaya,seems like your dvd lens is dirty or damaged.try using a dvd lens cleaner disk,or you have to change your dvd lens.
May 10, 2008 | Wharfedale DVD-M3 DVD Player
Have Wharfedale portable dvd player WDP-1210 will read audio cd`s but not dvd`s. Help.
I have a wharfedale dvd player wpd-1210 it will read audio cd's but not dvd's can you please solve my problem.
Apr 16, 2008 | Wharfedale Televison & Video
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Jan 03, 2008 | Wharfedale DVD-M3 DVD Player
Charger
www.pclaptopgarage.co.uk
Dec 19, 2007 | Wharfedale DVD-M3 DVD Player
Problem with wharfedale dvd player
press clear/Add twice and number 5, it has to be in monitor mode
Nov 22, 2007 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
212 people viewed this question
Top Televison & Video Experts
