Question about Whirlpool CAM2752KQ Top Load Washer
Whirpool washer wont work
The washer filled last night and this morning it was filled with water. Wont agitate, spin or drain. Need help with how to drain the water and what could be wrong with it.
  • Mike Smith
    Mike Smith May 11, 2010
    Did you try a different plug , using an extension cord , or check the circuit breaker ?
    President:
  • 3,113 Answers
The lid switch, get something to hold it down to make machine work. Turn machine on and push down on lid.
Posted on Jul 26, 2009
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
My whirlpool thin twin washer wont agitate it just makes loud sound but will fill up with water
Your washer most likely has a broken drive coupling. If broken the washer will fill with water and drain, but the motor spins without driving the transmission (no agitate or spin). The part is common to all whirlpool washers made in the last 20 years and is readily available at all major appliance part stores. It is possible to change this part yourself but much less hassle to get it changed by a pro
1485646-1-s-jpg.jpgSee Part # 13
Search all parts
in this section
USE WPL 285753 (Direct Drive Motor Coupling)Part Number: PS1485646
This coupling kit is used between the motor and the transmission on direct drive washers with no belt. This is the newer version and is made with new metal sleeves for added strength.
CAD$12.81
Oct 24, 2012 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
Whirpool Washer LSQ9500LQ0 Won't Spin or Drain
Your belt assessment sounds correct on the dryer problem.
If you can, restore the lid switch connections, and operate the switch during what should be spin. You should be able to hear a relay or solenoid clicking off and on with the switch.
Aug 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore model #110.26442502
Hello dagreen,
Welcome to fixya.
I'm Huuum and happy to assist you,
You said,
Last night you filled the washer with a comforter and pillow cases! It was working fine and then you lifted the lid. Now it wont start back. Any ideas. It is full of water and had already started agitating.
Check the breaker
Could the power be out due to an electrical storm while you were sleeping.
If not!
Try pulling the plug out for 5 minutes or turning the breaker off if you can't reach the plug.
Then try to start. this should have reset the system.
Some Questions to check
• Is the drain hose clogged, or the end of the drain hose
more than 96 in. (244 cm) above the floor? See the
Installation Instructions for proper installation of drain hose.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
• Is there excessive sudsing? Always measure detergent.
Follow manufactures directions. If you have very soft water,
you might need to use less detergent.
let me know how you do and that it works.
Huuum
please remember to leave a rating when your finished.
Sep 26, 2008 | Kenmore 24032\24036 Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Whirlpool CAM2752KQ Top Load Washer Logo
235 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
