Question about Toshiba Satellite M100 Notebook
Computer was in hibernate or sleep mode when the battery drained. Now, will not boot, appears to come out of sleep mode but only shows TOSHIBA splash screen and the hard drive lights do not activate. F8 (or any other function key) will not force it into recovery mode. Have removed battery, run on AC only, tried battery only all with similiar results. Suggestions
  • 746 Answers
Dear! take display properties use tab ans select screen saver then click on power and use tab again select hibernate if it is enable check again it and disable now. After that your computer will not go in sleep or hibernate mode.
Thank You
Posted on Jul 26, 2009
VPCSA does not properly go to sleep / hibernate
My advice is to shut down and unplug the Laptop when not in use. Set the Power Options to High Performance, set Sleep and Hibernate to never, adjust your Advanced Power to shut down when lid is closed. A reboot everyday resets the computer and IF there is a Power Surge your Laptop will not get fried. If left plugged in the battery COULD malfunction and become a fire hazard. Not to mention the unnecessary power applied to components and shortening their lifespan.
May 08, 2013 | Computers & Internet
Problem restarting toshiba satellite c660 from hibernation mode
Go into power options, select hibernate and uncheck the box to the left, this will disable the feature, microsoft worse piece of software. This will free up disk space and improve performance, best of all no sleeping computer to wake up.
Jul 08, 2012 | Toshiba Satellite P105-S6197 Laptop
My toshiba laptop has gone into hibernation how would i get it out of hibernation please?
To get out of hibernation on all computers with Windows....you simply have to push the power button once and the system is supposed to come out of it. If it does not, power the laptop off, remove the ac adapter power and then remove the battery. Push the power button to bleed any residual power in the capacitors. Plug in the AC adapter and power the laptop back up. It it boots, go ahead and replace the battery. You then may have an issue with hibernation on that particular computer. My advice is to go to the control panel > power options > hibernation tab and uncheck usinf hibernation. Most modern computers do not need this if they are sleeping or if you just want to shut the system down. There have been more bad registry problems with hibernation than any other thing.
Jul 09, 2010 | Toshiba Computers & Internet
I ussually put mi laptotp to a hibernating mode but now I cant get it started the message it shows says: "hibernating" and its been like this for more than 3 hours How can I solve this?
Power off the laptop, remove the ac adapter, and remove the main laptop battery. Push the power button in for approx 15 seconds. This will bleed all power from the capacitors. Now, replace the battery and attach the ac adapter. Power the computer up. When it boots, go to the control panel > Power Options > On the top of the window you will see the hibernate tab, click on it and un-check the hibernate box. Hibernation will and can destroy parts of the registry. Sleep mode is fine for most laptops....hibernation is not.
Jun 30, 2010 | Dell Inspiron 1545 Notebook
Put my toshiba laptop into sleep mode closed the lid, reopened it within seconds, and now the laptop will not come back on
Reboot the laptop, go to control panel > power options > go through the settings, especially what does the computer do when lid is closed and change the setting to "do nothing", turn off hibernation if it is on. Change other settings to now allow the computer to go to sleep, just let it run until you decide to turn it all the way off. Sleep mode and Hibernation cause more problems than do good.
Sep 17, 2009 | Toshiba Satellite A215-S7422 Notebook
Dell pc
You have a low battery or battery might be busted or you are in hibernate/sleep mode. Try removing the battery and hook the AC adapter then boot up. It should boot up windows.
Sep 15, 2008 | Toshiba Satellite A135-S2386 Notebook
Laptop apprears to go into sleep mode while I'm using it
To my knowledge it could be hibernate mode for laptops to save battery life when not plugged into the wall, try pressing the power button, my Compaq did that too. Also don't hold down the power button as after 5 seconds it just shuts off the laptop, unless you wanna do that.
Jan 14, 2008 | Toshiba Satellite P205-S6287 Notebook PC
No boot, screen blank after hibernation
NTLDR is missing Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in.
Getting into Windows Safe Mode Users who may not be able to boot into normal mode or are not able to .... This is the most basic Safe Mode option and has no additional support.
Good Luck, Please dont for get to Vote/Thank You.
Dec 26, 2007 | Acer Aspire 5610-4648 Notebook
Can't get it out of Hibernation...
my toshiba laptop went into sleep hibernation mode,& all i could get was the cursor on screen but nothing else, omg could not get it out of this mode for about 5-10 minutes,so i held the on/off button down for 10 seconds until it definately switched off,then was able to be reboot the laptop,but took some time doing this......
Oct 30, 2007 | Toshiba Tecra 8100 Notebook
Stand by icon locked Toshiba Satellite 1115-S103
i really need more info, two things:
firstly look to see if the clip (where the screen clips onto the base when it closes) is mobile and is not jammed down from something.
secondly restart, if a image comes up in your POST (when the computer boots up) push tab and then F8 or similar (it will say just read the screen = ] ) and restart windows in safe mode.
when you have booted up in safe mode check in the display and power window and tell the computer to never go into sleep or hibernate.
like i said i need more info cause this can also be caused bu a hdd contact error, or a battery falure, so please if this does not help in the slightest just post up here more info and i will be happy to help further.
good luck.
Oct 29, 2007 | Toshiba Satellite 1115-S103 Notebook
Computers & Internet Logo
250 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
