Question about Nikon D90 Digital Camera with 18-105mm lens
When on Auto setting the F-Stop starts flashing when you press the shutter button and it wont allow you to take any photo's, any suggestions?
  • 138 Answers
What type of lens are you using? if it is an AF-D .. put your aperture ring to the smallest one (biggest number). F22 or F36 depending on the lens you are using.. try again.
Posted on Jul 31, 2009
Canon t3i will not fire
Have you got the camera set for mirror lock up. Check and disable if appropriate. When mirror lock is selected the first press of the shutter button moves the mirror up the second press fires the shutter
Mar 23, 2017 | Canon EOS 600D Rebel T3i Digital Camera
My canon EOS 400 D will not take a photograph. I have selected 'full auto' and when i press the shutter button the speed and f number are displayed in the viewfinder together with the number 9 at the right...
The flashing green dot is telling you that your settings aren't right for the conditions. You have to bring in the settings within range. As long as the dot flashes, nothing is set right. Put camera on auto mode. Then take a photo. look at what the camera set the f stop, iso, etc. That will help you learn to set manual settings in the right direction. I have a 30 d and it will do same thing if setting in the manual settings are not right.
Feb 20, 2011 | Cannon Cameras
Olympus E-300 Evolt when you press the shutter button to take a picture, the shutter rapidly repets for about 9 times
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Jan 27, 2011 | Olympus Cameras
Shutter speed on the auto mode of my s1000 camera seems slow. how can it be increased in the auto mode? This is a Fuji camera and by the time I press the shutter button subjects have moved. I have set the...
You need to press the shutter button half-way and allow the camera to lock in the focus before you press the rest of the way. This eliminates "shutter lag".
Dec 30, 2009 | Fuji FinePix S1000FD Digital Camera
Turn it off and on again, or remove the battery. when you turn it on again and have the same message, remove the lens and return it back again. The problem is with the lens, 18-105mm, it is made of plastic mount that causes the camera to have error. I experienced the same with my D90, but when I changed my lens from 18-105mm to 18-200mm, the problem doesn't appear, coz the 18-200mm have the steel mount. I tried to use the 18-105mm with d200, and have the same problem, so i conclude that the problem is with the lens itself.
Jul 11, 2009 | Nikon D90 Digital Camera with 18-105mm...
How can I point and shoot with my Fuji Finepix S1000fd? I press the shutter button and it goes through all sorts of focasing, Etc. What if I want a candid shot and want what is going on when I press the...
Be sure you are on auto. Pressing the shutter release down half way causes the camera to focus. This needs to happen to get a clear picture. Be sure you have adequite light or the auto focus will not work. You might need to set your flash to auto as well . Them by pressing the shutter release the rest of the way down, you will get a picture. But gain, you need to allow it to focus first, then take the photo.
Mar 08, 2009 | Fuji FinePix S1000FD Digital Camera
Flash problems
As you haven't said which shooting mode the problem occurs under (e.g. Auto, Scene etc) I can only suggest that you try different shooting modes to gain access to changing the Flash settings. Hope this helps.
Apr 29, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Flash
I assume you have a digimax D53 as this is where your question is posted. On the top of the camera is two black buttons and the silver button which is the shutter release. One of the black buttons, the one closest to the silver button, is marked with an "M". This button can be pressed while the camera is on and it will allow you to change the settings for flash and for exposure. Suggest that you change it to auto as this is all around the best setting for snapshot type photographs.
Mar 22, 2008 | Samsung Digimax D53 Digital Camera
Outdoor pictures reveal white on LCD screen
The sensor for the auto-ISO may be working incorrectly. Try changing the ISO manually for different light modes. You can also try to change the white balance of the LCD. -Setting the white balance: 1. Set the camera to still image mode 2. Press the "Set" button 3. "White Balance" should be the current selection 4. Press the "Flower" button or "Flash" button to move through the available options for white balance 5. Press "Set" again when change appropriately - Setting the ISO: The higher the ISO value, the less light the camera needs to make an exposure, allowing the same exposure to be achieved with higher shutter speeds or smaller apertures. In a digital camera, higher ISO value allows higher shutter speed, at the expense of mottled or grain appearing in the final picture. 1. Set the camera to Still Image mode. 2. Press the "Set" button. 3. Press the "scn" or "timer" button to select ?ISO?. 4. Press the "Flower" or "Flash" button to select the desired setting. 5. Press the "set" button to select. 50/100/200 In the same lighting condition, the higher the ISO value is, the faster the shutter speed will be. I hope this helps.
Aug 06, 2007 | Polaroid i832 Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
179 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
