I have a samsung dlp (HLR5067WAX/XAA). I turn the unit on, the bulb lights, the green lamp blinks for 20 seconds or so (like normal), then the lamp light goes off (like normal). The set stays on for about 60 seconds, the picture is completely black. From my research it appears I need to replace the digital board (bp94-02084a) or the DMP board (BP96-0220A). Is it possible to determine which component is at fault. ie hook a computer up to the DVI input on the DMP board?
  • dan4540 Jul 26, 2009
    Please read the question again. The last
    sentence is asking how can I determine which board is
    causing the problem?
    Is the DVI connection on the DMP really a DVI connection? I could connect a computer to that connection and see if it displays a picture, thus rulling out the DMP board.
  • 3,037 Answers
I realize this is not what you are wanting to hear but there is no easy way to test these boards. I wish it was as easy as telling you which part failed . TV repair shops have a lot of money invested in electronic test equipment. If there was a way to tell without diagnosing the TV they could save lots of money by not purchasing this test equipment. Heat is the enemy of electronics, and these sets operate hot. These sets are assembled using the wave soldering process they are known for having cold solder connections. This model of TV has over 3,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective which most likely is a problem on yours, see if you find any with swelling tops as that is an indication of being bad. Resistors will change value and burn and sometimes look burnt so any with infinite resistance should be replaced. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail.
Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
A good start would be to have a multimeter which measures (voltage, current, and resistance), you can buy these at Radio Shack. If you owned and know knew to operate an oscilloscope that would help too. At least you have two boards to start on and start seeing if any parts aren't giving a good reading, though you would probably be better off trying to replace a board even though it will cost more, maybe a shop would let you try a board and return it if it doesn't work though usually they won't but its worth a try. Let me know how this turns out.
Benjamin
Posted on Jul 26, 2009
  • Benjamin Patri
    Benjamin Patri Jul 26, 2009
    Well yes, I guess you could do that then and see if you get an image. Usually we track down components that are failing or try swapping boards right away to see if one will work.
  • 10,594 Answers
In this DLP TV, Digital and DMD boards are not suppose to be repaired at component level nor spare parts and schematics are available in related service manual for subject boards. So only solution is to replace defective board.
Click Part Store to get price info as both boards are available there.
Thanks.
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Samsung HDTV - HLR5067WAX/XAA - popped, went dark
You had a surface mounted capacitor (AKA "CAP") let go on one of the circuit boards, open the set up and look for a small burnt area on the circuit boards inside the TV, it is likely it will be the power supply board, but that is just a guess..
Apr 13, 2017 | Vivitek Televison & Video
I have a HDTV DLP TV HLT6187SAX/XAA I have problem with the color, now all in green, red and yellow. the blue was gone. I want to know is that the problem from the lamp or the bulb?
He is talking about the HLT6187SAX/XAA which is an LED model not the HL-T6187S model which has a lamp unless he gave the wrong model number in the original post.
Jan 18, 2011 | Samsung HLT6187SAX 61" DLP HDTV
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
Samsung HLS4266WX/XAA warnings w/ new lamp also
You may be in need a new ballast, the assembly that excites the bulb into producing output.
Sep 20, 2017 | Samsung Televison & Video
Televison & Video Logo
216 people viewed this question
Top Televison & Video Experts
