Question about Harley Davidson 426290 AM/FM Radio
Need new end for display plug in for harman/kardon
When taking out the harman/kardon unit for ipod use in our old car. the plug in for the display broke off. Is there anywhere we can get a new wire or fix this wire & plub?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Harley Davidson Expert
  • 281 Answers
Iron Cross Audio may have what you need (www.ironcrossaudio.com)
Posted on Aug 10, 2009
Harman kardon go and play don't have video out port
If I understand you correctly the Harman Kardon does not supply the output video and usb ports. Since this is a go and play they pobably felt it was not needed. to impliment these changes would require a complete design change.
Mar 28, 2012 | Harman Kardon Go + Play Portable Speaker...
Harman Kardon speaker jack broken. What to do
if you know how to solder you can just remove the jack and replace it with another one, of course you can ask someone else to do it at a nearby electronics store
Dec 12, 2007 | Harman Kardon Harmon Kardon SoundStick II...
MY HARMAN KARDON GPS-500 WILL NOT CHARGER
If purchased in last 2 years will still be under warranty Harman Kardon support recommends Return to retailer for return to harman kardon for repairs.Seems that the battery and charger units for the gps500 models are not that reliable and as such may fail as fit for purpose.Contact retailer for returns policies in regards of warranty of units
Sep 10, 2010 | Harman Multimedia Harman Kardon Guide+Play...
I have a denon ipod dock and a harman/kardon receiver. Can I connect the dock to the receiver?
To plug the dock into the receiver to supply power and interface with the iPod you would have to have one with a built in iPod. Most receivers will not do that, the most common way to connect an iPod to a receiver is using a 3.5mm to RCA cable. You don't even need the dock to do this, you can plug the iPod directly in. You can find this cable at most electronics shops if you don't want to buy online, like Best Buy or Radioshack.
Make sure you connect the white and the red end of the RCA cable to the correct sockets on your receiver, and the small 3.5mm jack into the iPod or the iPod dock, you have to turn the iPod volume up and select the corresponding input on your receiver. If you plugged the 2 RCA jacks (white & red) into the socket labeled "AUX" or "Video 1" you have to select "AUX" or "Video 1" in order to hear the sound.
Jun 18, 2010 | Harman Kardon Audio Players & Recorders
No Memory Stotred in Harman Kardon AVR 65
You have a memory cap ,usally located on the front display,that is most likely defective.measure voltage on cap with unit off should measure at least 3-5 volts
Apr 10, 2010 | Harman Kardon AVR 35 Receiver
Ipod to harman/kardon
Using a headphone to RCA adaptor plug the headphone jack into the headphone connector of the Ipod. Then plug the RCA jacks into any available Analogue input on the receiver. Increase the volume on the Ipod to 80% then adjust the receiver's volume according.
Or get a dock that will allow remote control and charging, such as Roth, DLO or Wadia.
Dec 19, 2009 | Harman Kardon AVR 35 Receiver
My Harman Kardon FL 8550 will not play, the display shows error and the carousel seems stuck. I already cleaned the lens.
Couple possibilities.
Disc jammed inside, take cover off and inspect.
Worn belts, belts are old and worn and it can't move the carousel or open, stripped gears will also have the same effect.
Or electronic problem, not worth repairing.
Nov 27, 2009 | Harman Kardon FL8550 CD Player
Nano 8gb does not charge battery(3th generation)
the ipod of the 4th generation does only charge in USB mode and the Harman & kardon speaker only supports I link charge mode(fire wire 1394) so i bought an awsome sounding machine wich does not charge my ipod nano.
however i must say that i have a solution, when you put the USB cable in the back of the H&K, you can charge the nano with a charging device of an ipod.
greetz leon
May 27, 2009 | Harman Kardon Go + Play Portable Speaker...
Harman Kardon go + play problem
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try cleaning the battery terminals. In some instances, it may be necessary to scrape them to remove corrosion. Still there are times they may have to be bent or stretched to ensure that they provide more pressure to the batteries. Alternately, pls try to confirm that the AC adapter is working by checking for the presence of voltage on the plug/connector with the use of a voltmeter.
Should the above not address your concern, then it is most likely that the problem is internal electronics and the unit is simply going into protective mode. You then have a choice of performing a DIY (do-it-yourself) or seeking the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 22, 2008 | Harman Kardon Go + Play Portable Speaker...
Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Jan 21, 2008 | Harman Kardon SoundSticks II Computer...
Harley Davidson 426290 AM/FM Radio Logo
127 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
