Question about Garden
Charger wont recharge dead batteries, says "fully charged"
  • 1 more comment
  • perxbvq Jul 26, 2009
    thanks.
    batteries are 14.4V
    they have four contact blades
    crossing the two blades perpendicular to the long axis of the battery = 13V
    """"""""""""""""""""other blades (parallel to) """""""""""" =13V
    when inserted in the charger, only the middle of the three lights lights = "fullly charged"
    I discharged manually the pair of "other" blades to 3-6V and reinserted the battery and it still says "fully charged"
    the whole deal is about two years old, but has been used only occasionally. In fact I dont think I ever found it necesssary to recharge the batteries before now... they are ni-cads
    thanks for your help
    paul
  • perxbvq Jul 27, 2009
    thanks for your help-
    it remains a constant in my life that just having someone else helping you with a problem results in a solution - and it has happened again for which I thank you very much and will rate you 100%!
    here is what happened: I was multi tasking- hence the slowness of my responses to your suggestions.
    even though only the yellow "fully charge" light was on, I had just left one of the batteries in the charger. After your most recent message and an interval of about an hour, I went back tp the charger and pulled the battery out, and damm but the battery was nice and warm!
    AND IT WAS CHARGED AND RAN THE DRILL WITH GOOD POWER!!!!
    so I stuck the second battery into the charger and noticed theyellow "fully charged" light blinked and the red light "charging" blinked ON! but then the red light went out and yellow light came back on. so I rotated the battery in a grinding motion on the transformer as much as the slack in the charger plug would let me- and found I could get the lights to do that again- red on yellow off--- yellow on red off.... SO i FOUND A POSITION WHERE THE RED WAS ON AND THE YELLOW OFF AND CHARGED THE SECOND BATTERY WELL TOO! SO THE PROBLEM IS CURED AND I THANK YOU FOR HELP! paul
    its fixed !
    thanks a lot
    good deal
  • 6,674 Answers
Do you have a multimeter by chance?
Posted on Jul 26, 2009
  • 3 more comments
  • Mike Butler
    Mike Butler Jul 26, 2009
    How old are batteries & charger?
  • Mike Butler
    Anybody there?
  • Mike Butler
    Do same (DC voltmeter) across charger tabs, where battery makes contact, with charger on, and see what readings you get there and get back to me.
  • Mike Butler
    Please help me out with a rating when your satisfied. Thanks.
  • Mike Butler
    Mike Butler Jul 27, 2009
    Great ! glad to hear it Paul & thanks for reply. If you could check off fix for rating, we'll all be good.
    Thanks again. Happy Cutting.
Battery charger issue
funny thing with batteries is that they can get a memory = sounds stupid yes = if a battery is recharged when it has half charge and then fully charged it remembers the point , one it gains memory it wont charge past the last point = or the battery life is over = or the charger is faulty.
Jun 12, 2014 | Samsung S1030 Digital Camera
Charging camera
I think that your batteries may have expired due to old age and are refusing to hold a charge.
Ni cad batteries have a shelf life and once that time limit has expired, you need to replace the batteries with new ones which will begin counting down to their expire date and also go dead.
once ni cad batteries have expired and past their time limit
nothing can be done to revive them ,they are forevermore dead and must be replaced.
that is the reason why i buy 120 volt ac drills instead of battery powered drills which are always dead by the time i need to use them and wont hold a charge when i try to recharge them.
my cordless radio phone batteries go dead after 1 hour on the phone, when they were newer,i could talk for 4 hours and still have 1/4 charge left. soon they will only last 30 minutes and need a 12 hour recharge to come back to 4 bars.
so i expect to have to pay 4 new batteries by christmas.
One other option may be that your charger is not working properly and developing the required voltage.
that also happens but not as often as dead batteries that wont hold a charge.
if you have a radio shack nearby, even if its a 20 mile drive
they can test your batteries and also test your battery charger. just ask for a salesman that has a battery tester and a vom [volt,ohm,milli amp meter] also called a multi meter. The vom will test your charger and came also test your batteries, but most salesmen dont know enough about the vom to use it as a battery tester .
PS a battery tester is just a vom scaled down for battery testing only, made easy to use for dummies.
Oct 09, 2013 | Pentax Optio Cameras
Included in my Ryobi printed instructions are the statements: 1-"Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode. 2-"To obtain the longest...
Any battery left in a charger is still hooked up to a circuit. Depending on the charger this can mean a slow discharge is possible. Ryobi's Maintenance Charge Mode means the charger will 'refresh' the battery at regular intervals, usually every 30 days. A battery's lifespan is determined by how many times it is discharged/recharged so to get 'the longest possible battery life' it is desirable to reduce the number of times a battery is recharged. One way is to use the battery until it is dead or near so another is to remove the battery from the charger when it's fully charged to reduce the number of times the charger refreshes the battery.
Dec 23, 2010 | Ryobi Multi-Volt Battery Charger
Power Problem Samsung Exclaim
You can try running the battery completely dead and then recharging, but it sounds as if you have done that already. I would recommend purchasing a new battery as it sounds like it is dead.
Apr 03, 2010 | Samsung Exclaim M550 Cell Phone
Both batteries show full charge but don't last 10 minutes. Only had the tool for less than a year.
rechargeable batteries can build a memory, if you use it say for 5 minutes and then put it back on the charger - then the next time you use it for 5 screws and put it back on the charge - see where I am going
Over time the rechargeable batteries "learn" they only have to work for 5 minutes ( dang my son was that way)
You need to fully drain them and recharge them fully several times might take 10 times.
We have a program in our shop that when you are done with a battery it goes in the flashlight until dead, dead, dead then to the charger. I have batteries that are 10 years old and still work almost like new.
You may have to replace yours but it is worth a try
Mar 09, 2010 | Makita Cordless Impact Driver Kit
Kodak C340 I installed new batteries and docked it over night and the camera still dose not turn on
with new batterys you may find if quicker to charge them in a battery charger and not in the camera,,,the camera charger is for "topping up" the batterys realy not fully recharging them its so you can leave the camera on its docking port and it will have fully charged batterys in it when you wont to use it,, to fully charge a new set of batterys it could take days,,,,so overnight is to short a charge to recharge them,,,leave the camera on its docking station for a fuw days at least, or use a home charger for your type of battery ie:AAA or AA, both take 16 hours to recharg fully
Feb 16, 2010 | Cameras
Battery in Jeep Grand Cherokee dead this am and less than 1 year old. I have a Everstart 100 battery charger plugged in and on the car. How long does it take to charge the battery. The charger is plugged...
How many amps does this charger put out????
A small trickle charger will take forever to fully recharge a dead battery, you'll need to have a battery charger that can put out enough amps to properly charge a dead battery.To clarify, the chargers sold at Sears, the large square types on wheels are the best for charging dead batteries and they also have an amp meter telling you how much the battery is accepting. After you charge your battery, you should be around 12.5 volts to 12.7 volts. DO NOT OVER CHARGE!!!
Jan 18, 2010 | 2004 Jeep Grand Cherokee
Will replacing the alternator belt on 2000 hyundai recharge the battery that has almost gone dead in 24 hrs of non use? Is this belt replacement expensive and or covered under hpp 4b?
not its not coverd under hpp, but if the belt is slipping it wont charge very well, also an alternator was never intended to recharge a flat battery only to keep it toped up,,, if its tottle flat it would be best to recharge it with a mains charger first as the alternator will never fully charge it from flat,, unless you drive around the world first??? it would take years to do it,,,if ever,,,charge the battery first with a mains charger
Nov 12, 2009 | 2000 Hyundai Accent
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 | Drills
PSP CHARGING PROBLEMS
The way to properly break in a lithium Ion battery is to run it dead before you recharge it. Then fully recharge it and run it until it's dead again. Do this about 3-5 times and then the battery is properly broken in. If you charge it before it dies on a new battery you can build what they call a "memory" where the battery thinks it's fully charged however it's only maybe half charged and you will lose alot of life out of your battery. So make sure you properly break it in.
Feb 02, 2008 | Sony PlayStation Portable (PSP) Console
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
