Question about Maytag Washing Machines
How to replace tub seal on Maytag sav4655eww
How do I replace tub seal on Maytag sav4655eww washing machine?
  • mike_harden Jul 26, 2009
    i have the tunb and transmission completely out. how to I seperate the trans from the tub? my local repair shop said their is no spanner wrench for this model. I removed the agitator and plastic nut, and the 4 bolts inside the tub. now I see a nut? with 8 tabs on it. try turning both ways no luck. thanks for the help.
    President:
  • Maytag Master
  • 1,922 Answers
You need a 1/4" nut driver and a spanner wrench-start by taking 1/4" screw located toward lower part of agitator,its recessed,take it out,then lift out agitator, then mark where your drum is so you get replaced in that location(counter-weights)then take spanner wrench and loosen nut that holds the wash tub and lift out tub,turn tub over and w/rubber mallet driveout old seal,to aid in new seal install lightly lube with vegetable oil(wessonoil-pam cooking spray) and tap seal into place and re-install in reverse order
Posted on Jul 26, 2009
We have a maytag la712, recently replaced the shaft seal and main shaft bearing sleave. No when the machine goes from wash to rinse cycle it is leaking. Looks like it is coming from the backside of the...
Do you mean the Boot Seal assembly and Tub bearing were replaced?????
Who did the replacement? Does your machine have a plastic tub cover with some 8 or so tabs that lock it onto the tub?? The gasket may be warped or the tabs are not locked in the right place.
If it has a metal tub cover then probably the rubber gasket is twisted and not seating properly between the tub and the cover.
May 24, 2017 | Maytag Washing Machines
We have a Maytag top-loader model A482 which is probably 25 years old. I found water on the floor under the machine when the last load finished washing. What's the first place to look for the leak? I'm...
The most common thing that will cause a leak is the tub seal. If the tub seal is leaking water will be comming from the center of the tub where the transmission meets the tub. This page will show how to replace the seal. http://appliance-repair-it.com/Maytag-tub-seal.html
There is also an air-gap that will often leak. If this is the case the water will be comming from the left hand side at the top. The air-gap is in line with the water inlet. This page will tell more http://www.appliance-repair-it.com/Maytag-washer-leaking.html
If they are not the problem you will have to look for a leaking hose or something to that nature.
Sep 28, 2010 | Maytag Washing Machines
Model # LAT9593ABW washing machine leaking - cannot get the lid / cover off to check where the leak is starting. thanks
This page shows how to remove the front. Also if the tub seal is bad (video shows how to tell) there are directions on how to replace it.
Sep 21, 2010 | Maytag Washing Machines
Makes loud noise in spin cycle
The problem is that the seals are leaking and allowing water to attack the tub bearings.
You need new tub seals and bearings.....not as difficult as it may seem.
see u tube video on replacing maytag seals and bearings
Cheers Stan
Aug 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag Dependable LAT8824AAE. Main tub seal leaks
The part number for the mounting stem and seal kit is 6-2095720 it cost about 85 bucks retail. You will also need to buy a special maytag spanner wrench to remove the inner tub. Its NOT an easy job the inner and outer tubs and hoses all need to be removed. The seal kit comes with no instructions. If you had a service company do the job it would be probably around 250 maybe more. We charge 104.95 labor for the job. Good luck _MJ_
Mar 04, 2010 | Maytag Washing Machines
Maytag A806 washing machine leaking from the center,under the tub
The tub seal is bad.
I had the same issue on another model.
You can attempt to repair this yourself. I suggest that you do a search on Youtube to see if this is a job you want to take on. It took me 2 hours to change mine. The seal kit and tools are sold online.
Good luck.
Sep 27, 2017 | Maytag Washing Machines
Control dial moves along fine but drain,spin, rinse never happen
replace the water pump. about 46 dollars and a 20 minute job.
Jun 24, 2009 | Maytag Washing Machines
Brown stains from wash machine
Hi!!! Your tub inner seal is worn off its a seal which protects the inner tub fron the transmission..Need a new tub seal..Good luckk..
Jan 03, 2009 | Washing Machines
Maytag washer tub seal bearing kit - grease?
how do i change bearings and shaft ona maytag washer model# mvwb300wq0
Jun 17, 2008 | Washing Machines
Washing Machines Logo
420 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
