Question about Goodman Heating & Cooling
Split straight air system with outside unit comes on and air handler does not whether on auto or on position with temp down or up
  • 26 Answers
Either the thermostat, fan relay on circut board or blower motor bad. Jumper the R and G terminals together on the circut board, depress the door switch and see if the blower runs, if not, check for power to motor, capacitor and motor windings. If it runs then you have tstat/control voltage wiring problem.
Posted on Jul 26, 2009
Air handler blower/fan wont come on.
open it up and vacuum and blow out the fan and other areas
Feb 28, 2014 | Amana ASPF183016 Multi-Position, Air...
Will not switch on
There should be a box near that. Electric fuse or breaker might be in that, check it. be careful! it is high voltage. Check the other breakers too. If that is not it, let me know
May 02, 2013 | Rheem Complete Split System Straight...
Were is the reset button on the unit?
Hi, here is the theory on the reset button on Air Conditioners. They reset via the breaker panel box in your house. Check that first before anything else. However if your unit is popping breakers, it is because the rating for the breaker is incorrect, or there is something that needs servicing usually in the outside unit called the condenser. That piece contains the compressor. A faulty compressor and pop the breaker. Or If the condenser fan that blows over the coils of the outside unit stops (common failure) The compressor will overheat and shut down. That may not trip the breaker but the house will get hot anyway. Usual action for this is to replace the condenser fan motor and starting capacitor. Make sure the speed rating and directional rotation for the replacement motor is the same as the motor removed.
There are other reasons why the system won't come one fully. If the wall thermostat is digital and does nothing. including turning on the fan. There will be a small fuse located on the circuit board of the air handler (part of Air Conditioner mounted inside the house. It houses the circulation fan). That fuse could be blown. That one shuts down just about everything.
On air handlers mounted up into the attic crawl space there is an overflow pan. This pan is mounted directly below the air handler. This pan can fill with water when the drain pain contained inside the air handler starts to overflow because the drain system to that is clogged.
There is a "float switch" mounted in the overflow pan wired to the system in such as way as to shut down the entire AC system if that pan fills.
The handling is to clear the obstruction in the Drip Pan inside the air handler. Then remove enough water from the overflow pan and the AC will run as though nothing has happened.
If you have more questions, write to me on this site.
One thing more. The capacitor alone in the Outside condenser unit can fail and that will stop the condenser completely if it is of a "split" design and used for both the compressor and fan. When replacing this unit alone, ALWAYS find the same specification part.
I hope this helps,
Have a Happy New Year,
Mark
Jan 02, 2011 | Goodman CLJ30AR32 Air Conditioner
I have a Ruud 2 ton split system and the system will not cool. The compressor and fan on the outside unit works and the fan blower on the air handler works too. The temp on the lines coming into the...
The small line coming in from the outside unit should be warm to hot and the larger line should be cool and sweating with water forming on it. I am taking for granted that the unit was working if so it sounds as if the unit is low on freon. your inside coil should be sweating a lot from top to bottom if it is only cool or sweating on the bottom but less to nothing up top you are low on freon. When very low the unit will stop working just like a broken valve in the compressor. If it is just a little low it will not cool properly and at night it might even freeze the inside coil up.
Aug 08, 2010 | Ruud Handle Air Conditioner
Have a Janitrol central air system and the unit outside comes on but the fan in attic does not always come on. If I go to the thermostat and manually turn it from auto to on it comes on. Any ideas about...
If the blower is working with the thermostat in the ON position that tells you that the fan motor works. In the AUTO setting... the system in controlled by the contacts in the thermostat. 1. The thermostat contacts might not be closing. 2. A contactor( or relay ) in the air handler unit(inside unit) might not be closing to send the signal to the fan motor. It sounds like a thermostat or relay problem to me. You can email me at Starztruck4u@aol.com if you have more questions.
Aug 05, 2010 | Heating & Cooling
No heat when outside temp low When outside temp is 38 or above get heat. Is there a heater in the compressor that can fail?
I would start with your outdoor thermostat located in
the unit outside. I`m assuming this is a heat pump.
When the outdoor temthermostat is set to say 40F
anything lower than that and you are not using the
compressor, you are using electric heat thats located
in the air handler unit in the house.
I`m also assuming this is a split system and not a
packaged unit. If you are mechanically inclined and
you can locate the outdoor thermostat lower it below
the outdoor air temp and see if the unit comes on.
Sounds like you might have a problem with your electric heat or emergency heat
Jan 12, 2010 | Carrier XQB101D Air Conditioner
My air handler comes on ,not the outside unit when my thermostat is in the off position even if i turn the thermostat down to 50 and have it turned off the air handler comes on for about 5 to 10 minutes...
If you have a standard thermostat the fan switch is for the air handler only. It completely over rides the thermostat for most settings. Now lets see this is what I'd expect:
fan switch on Indoor fan runs all time
Fan switch auto Indoor fan only runs when thermostat is set to cool or heat and the thermostat is turned up above room temp for heat or below room temp for cooling. In both of these modes the furnace blower comes on and stays on til the room temperature is satisfied. The outdoor unit only comes on for AC the out door unit will not come on for heat or the "on" setting on the thermostat. See exception 1 & 2 below...
Exception 1- (in a heat pump the out door unit runs in both heat and cool mode unless it has emergency heat turned on then it will not come on outside in the heat mode, and depending on the type of heat pump and furnace or air handler it is). A heat pump thermostat usually has "backup heat" and an "emergency heat" setting switch on the thermostat.
Exception 2 - On some thermostats they are made to cycle on the heat if the temperature reaches a preset temp (around 50'f usually but definitely by 40'f). This mode prevents freezing when if instance the homeowner is away or while the home is under construction. In this mode the fan inside can run but the heat usually comes on with it.
Exception3 - On some electric furnaces the heating strips may be individually controlled and thus not all come on at one time. This may give the feel of no heat especially if the room is cold.
Now there may be other exceptions but Ive tried to give you a heads up on some of the most common ones.
If you need more help please post more specifics about your unit/system as to for sure what switches are set to what setting and what is happening with each. My first though was that maybe your system is OK and you needed to know if the thermostat was working properly.
If this helpd you understand your problem would you please give me as hifgh a mark as you can. Thnaks for using fixya and good luck.
Mar 28, 2009 | Carrier Heating & Cooling
Cold Air Penetrating from around & thru GE Zoneline 2100 Unit
There is a baffle/damper that allows outside fresh air to flow through the unit. This is only supposed to be open in cooling mode when the outside temp is moderate, or whenever you want just fresh air and fan operation.
Find the lever that controlls the baffle.
Some units have a switch in the control panel for this.
Jan 19, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
