Question about Nokia Cell Phones
Downloading of photos
Trying to connect Nokia 6210 phone to bluetooth on PC. Passkey needed.
  • 1,555 Answers
Passkey is decided by you yourself i suggest give 1111
Posted on Jul 26, 2009
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
Bluetooth nokia 70 passkey
The passkey should show up while connecting a Bluetooth device. The passkey is subject to change per device.
Jun 01, 2011 | Nokia N70 Cellular Phone
How to connect to laptop?
You can connect Nokia 2690 using bluetooth and using Nokia connectivity Cable CA-101 which will fit to the USB port of your laptop.
(NOKIA connectivity cable)
Procedure on how to connect:
1. Bluetooth (This will work with the laptop with bluetooth)
First, remember to turn on the Bluetooth feature and make it discoverable by other devices (My Phone's visibility -> Shown to all) on cell phone, so that it can be detected by laptop.
Then, click on the add devices in the control panel of your computer. Click start> control panel
2. Add Bluetooth Device Wizard window will appear, tick My devices is set up and ready to be found and click Next.
3. The wizard will then search the Bluetooth devices nearby, and will show the found devices. Here the wizard found my cell phone named David. Click the device you want to add, after that click Next.
4. Ok. Here the wizard will ask whether you need a passkey to add your device, so that the communication data between laptop and cell phone will be encrypted later, here I would recommend you to either select Choose a passkey for me or Let me choose my own key. In this example, I select choose a passkey for me.
The wizard will then show the passkey and you need to key in to your cell phone. After that, the laptop will try to install the Bluetooth device. If you have Bluetooth program for your cell phone, you can install it as Windows Vista might have problem to install the device . For my case, I install Nokia PC Suite on the laptop, so I can transfer wallpapers and videos later.
Note: Also your cell phone will get the prompt to accept connection from laptop, and you need to click yes.
5. At last, click Finish to complete the Add Bluetooth Device Wizard.
6. And now, you will see the new bluetooth device added which is your Nokia 2690 phone.
Here's another way on how to connect your cellphone to your laptop.
2. Hard Connection using Nokia connectivity Cable CA-101
carloadrian_7.jpgYou can get this from any nokia stores.
Procedure:
Just connect the other end of the wire to your cellphone and the other end to the usb port in your laptop. Follow the onscreen instructions in your cellphone.
Check your laptop if your cellphone has been detected, once it's connected you can then access your pictures or other files in your cellphone. You can even transfer files.
I hope this helps.
Please rate this solution. Don't forget to leave your comments/suggestions on how I can improve my service.
Thanks..
Jan 27, 2011 | Nokia 2690 Cell Phone
Nokia 6210 bluetooth will not turn on
well, check ur guidebook and find bluetooth or just search in google or yahoo
Mar 28, 2010 | Nokia 6210 Navigator Cell Phone
How can i connect my bluetooth to my pc?
on pc side
1. give your host bt name
2. find bt COM port
My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
on phone side
1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
pairing
1. add device
host: go to My Bluetooth Places->Add new connection
phone: go to bluetooth, choose Paired Devices->add
2. provide passkey (4-digit, 0-9 only) on both
Check mRouter
check bt COM port that you found
Start bt serial
if you see mRouter turns green and blue, you got it
start pc suite
Oct 19, 2009 | Nokia 5000 Cellular Phone
Lost my plantronics 222 bluetooth passkey
trying to install my plantronics 222 blue tooth head-set to my nokia 7610,but it keeps asking for a pass code.
Oct 03, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Screen broken on nokia 6210 navigator need info from phone
Dear,
When u connect the phone with the pc, u just scroll down to image the mass storage. i hope, it will be the 2nd option. Go for it and u will be connected with pc for data sharing.
good luck
Sep 09, 2009 | Nokia 6210 Navigator Cell Phone
Cannot connect via bluetooth to Mac
The default passcode for the Pogo is 6000.
Sam
Mar 17, 2009 | Polaroid PoGo Digital Photo Printer
Aspire 3000 laptop
Normally you setup a passkey or use 0000 or 9999 as a passkey.
The question is, does that pop up when you try to connect a USB device? Do you get that when you try to install the dongle? (That shouldn't happen). If you are trying to connect a PDA or cell phone, you setup the passkey for the connecting device on the computer then type it in to the PDA or mobile phone. If you are trying to connect a bluetooth headset, then you use whatever code is from the manufactorer. Normally this is 0000 or 9999.
Hope this helps!
Oct 18, 2008 | Adapters.com Bluetooth USB Adapater, USB...
Cell Phones Logo
46 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
