Question about Refrigerators
Found frig to be defrosting on its own, I cleaned it all out and turn it off for several hours. pluged it in and left it running all night, it a little cool but no where near cold enough or even freezing??
  • Mike Smith
    Mike Smith May 11, 2010
    Need brand and model number to help .
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
When compressor is running, the fan beside it and the fan in the freezer should be running. make sure coils are clean. if there is frost build up on freezer wall, you may have defost problem that is blocking the flow of air.
Posted on Jul 26, 2009
Why will my frig not do it's defrost cycle? Could it be the temp Fuse - where is it?
First off try taking a vacuum cleaner and cleaning off your coils of any dust, dirt or hair that is blocking good air flow to make sure your refrigerant is as cool as possible before it hits the compressor.
If you have frost on your evaporator coils that means the coils probably are covered in an ice layer which stops the coils from absorbing heat from your refrigerator because believe it or not, 32 F ice is not near as cold as evaporator tubes with refrigerant running thru them at about -20F or lower.
So make sure there is a nice unobstructed air flow to condensing coils and fan so the heat from refrigerator compressor can be carried away properly.
After everything is really clean, turn refrigerator completely off for the night to make sure any ice formed on the coils is melted away. Any ice on the coils will screw up the thermostats and then the refrigerator will turn on the compressor to run even when it shouldn't
So do a complete manual defrost before going back on
Nov 20, 2015 | Frost Refrigerators
Refigerator is not cooling but the bottom freezer is working fan is running in frig are there 2 compressors? door was left open on the frig for several hours by a kid before problem started pls...
if the freezer is working fine - and the fan is running in the refrigerator I would give it a little time (24 hours) to catch up (from the door being left open).
hope this helps
Jun 14, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking water into frig when defrosts
The problem is the defrost drain is pluged. At the rear of the frig section up at the top you will see a small cup where the water drains into. I always used a large syringe with a rubber hose attached. Fill the syringe with hot tap water and flush the ice out of the drain tube. Once cleaned out and the water runs freely your problem will be solved.
Dec 27, 2009 | Kenmore Refrigerators
Refrigerator not cooling
It could have one of several problems. Is ice blocking the passage from the freezer to the frig? If so, then the problem is, it is not defrosting.
Or it could be it is not turning on after defrosting.
Either case would be a bad defrost timer. You can turn that with a screw driver till it clicks and see if anything happens.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
Or if turning the timer makes the compressor come on, then replace the timer.
If the timer is working, then perhaps the problem is the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Sep 16, 2009 | Refrigerators
Refrigerator not cold
first check your damper door from the freezer to the refrigerator compartment make sure its in the proper position. Then turn off the refrigerator for a few hours until the heavy frost melts away. turn on the refrigerator check the refrigeration cycle, is it working properly, is it going into defrost are the defrost heaters working.
Feb 21, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Help frig not cooling model # FRT21LR7A
You have to replace the electrical components on the side of the compressor. The heat from the fan not running by the compressor more than likely has damaged them. These are a safety feature to save the compressor from damage when it overheats.
You can find the factory repair manual here. This will have all the part numbers and what you need to replace to take care of your refrigerator. The Top Freezer Refrigerator one will be about your machine. It covers all the FRT Models.
Thanks
Jan 08, 2009 | Refrigerators
Auot defrost problem?
cleaning the condensor is nothing to do with evaporator freezing up. keep an eye on it - you may have a problem with the defrost cycle. problem can also happen if freezer door has been left open
Jul 21, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
