Question about Brother LS-1217 Mechanical Sewing Machine
Lever is stuck in reverse
Just purchased second hand sewing machine, tried to sew for the first time and found the reverse lever is stuck in reverse and am unable to sew properly
    President:
  • 1,952 Answers
If the stitch length bar, which is located on the right side of the machine, is in the up position move it down to where the numbers are. Those numbers are referring to how many stitches the machine will sew in an inch. Therefore, if you put it on 10, your machine will sew 10 stitches per inch. It being up will cause your machine to go in reverse.
Posted on Jul 26, 2009
My heavy duty Singer sewing machine is stuck in reverse. How do I fix it?
If this machine has a mechanical lever or button it may be internal parts have broken and need to be replaced. this is a common issue with lots of machines. The machine breaks when in reverse and will only sew in reverse. Please have a professional look at the machine and make a repair if necessary.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Singer Sewing Machines
Homestyles sewing machine F08 702 H 01: Are they ALL caca, or just mine?
If it was purchased second-hand, very likely something is wrong with the machine or the owner didn't know how to use it. It is always best to test and have the owner show you how to use the machine before purchasing. From the information found online, this is a very economical level sewing machine--even new.
JMHO, but purchasing an old mechanical machine from a sewing machine shop for $60 would probably yield a more reliable machine. For most sewing, a straight stitch and zig-zag are the most frequently used stitches. So, if you are unable to purchase an upper-scale machine with multiple built-in design stitches for several hundred dollars, stick with a simple mechanical.
Jan 01, 2017 | Sewing Machines
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
Sincerely
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
I have a Janome sewing machine, #423S that I have never used. It is second hand. It sews nicely, but I cannot find the reverse lever on it
The reverse lever should be below the stitch width lever. (It's a wide lever in its own recessed area. just above the level of the extension table.) See page 2 (page 4 of the PDF) available here: http://content.janome.com/documents/File/ManualFile/Inst%20book%20419S%20&%20423S1.pdf .
I hope this helps.
Jan 12, 2013 | Janome Sewing Machines
Europro model 6131 is stuck in reverse
I have never found any online instruction manuals and repair manuals are just as non-existent.
You can try jiggling the reverse lever while turning the hand wheel. Other than that the only suggestion I have is to use the machine for target practice.
Oct 02, 2012 | Euro-Pro 6131 Mechanical Sewing Machine
Yamata FY5318 reverse lever sticking
Have you really examined the machine? I had a machine binding on me once and found that the take up lever had been bent and it was binding on the upstroke.
Usually binding is a bent or very gummed up part or bits of thread causing issues. Get out your magnifying glass and some tweezers... time to pick clean and oil.
Sep 05, 2012 | Yamata Fy5318 Mechanical Sewing Machine
Machine sewing backwards
the reverse lever may be stuck. this is usually located on the right hand side of the machine, and is a lever that you can push down. sometimes it's a switch.
May 28, 2010 | Singer 5050 Mechanical Sewing Machine
Reverse lever
lever must be locked in. if possible, you must open it and try to look for something blocking it. maybe a faulty spring or something.
Nov 24, 2007 | Brother LS-1217 Mechanical Sewing Machine
Stuck in reverse
The reverse button is attached to link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it). In order to solve the problem, the covers must be removed.
Oct 26, 2007 | Kenmore 15208 Mechanical Sewing Machine
Brother LS-1217 Mechanical Sewing Machine Logo
1,258 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
