Question about Hunter 21564 The Brunswick Bronze Ceiling Fan
I have a hunter ceiling fan its about 20 years old. my problem is the remote will not work the fan. when i have the fan set on high speed the remote will only work the high and when i set the the fan on medium speed the remote will work the medium and low not the high speed
  • 52 Answers
There is a small black box in with the wireing on the fan unit ...this box controlls the fan through your remote ...it is esentially a switch this unit is likely the cause ...remove and replace .....
Posted on Jul 26, 2009
    Sergeant:
    Champion:
  • 246 Answers
I'm sure you put fresh batteries in the remote...right? Most of the time you can correct remote problems by carefully taking the remote apart and cleaning all the contact points with a pencil eraser.
My hunter ceiling fan turns very slow
Check your capacitor. If this is an add on remote, set the fan on high with the remote then pull the chain on the fan until you get high speed.
Sep 17, 2014 | Hunter 52" Ceiling Fan With Light And...
Hunter Ceiling fan lost medium speed, kept hi and low. Speed control capacitor melted. Replaced both capacitors (speed and start) AND switch. Still no medium speed. Is it possible part of the motor...
well, they could have. but before you throw it out, go to the hardware store, and buy a new pull switch. either that, or just run it with the high and low speeds. It shouldn't hurt it at all. But, if there is any clicking sounds, or wierd noises coming from it , DON'T USE IT!! it may catch fire. but it did last a long time. 20 years is good for a modern celing fan. though I like my antique 1907 westinghouse 72 inch 2 blade fan. It hasn't died yet!!!
Aug 12, 2010 | Hunter Ceiling Fan Control Switch
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Sep 08, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Our Hunter fan speed controller is not working. When we press high, it goes on high speed. When we press medium, it goes off. When we press low, it goes on high speed. When we press off, it goes off. Can...
Hunter's remote systems are notorious for failures. We replaced ours before the fan was one year old, and then it did it again within a year after that. The warranty, of course was on the ORIGINAL part, not the new part, so Hunter will never help you out, even though their remote receivers (the part in the fan) are junk!
Jun 30, 2009 | Hunter Ceiling Fan Remote Receiver...
Hunter ceiling fan is stuck on high speed
If it has a chain, buy a light dimmer switch so it will not have 1 speed anymore. If it has a remote control, buy a new remote control like your old one. Try different numbers on remote control.
Feb 05, 2009 | Hunter (25417) Ceiling Fan
Hunter ceiling fan barely moves
hi
check if the fan turn freely if not then it is most likely a stiff brg,if it does then it could be a capacitor failure or faulty winding in the motor
cheers
grantsreps
Sep 28, 2008 | Hunter (25417) Ceiling Fan
Hunter 21564 The Brunswick Bronze Ceiling Fan Logo
202 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
