Question about Oregon Scientific Starck Large Music PSL03A Clock Radio
Oregon Scientific Stark clock resets itself to PST.
Nowhere in the manual does it say how to set time zone - major flaw. How do I set time zone on this clock and stop it from resetting itself again?
  • 3 Answers
-Press SELECT once and time number should flash.
-Press and hold SELECT and it will enter settings mode for the clock.
-At the bottom of the screen next to the moon phase you should now see PST time zone.
-UP and DOWN keys will change the time zone.
-Press SELECT and other clock settings can be changed.
Posted on Dec 21, 2009
Cl-935
This model number does not appear to relate to Oregon Scientific. Look at these two manuals: they may answer your question: http://www.manualslib.com/products/Oregon-Scientific-Eb313hg-294871.html
Aug 03, 2014 | Oregon Scientific Handheld Weather...
Oregon scientific instructions
Which model Oregon Scientific do you have? There are a couple that you need to set the time zone with a switch on the back of the unit. For the BAR388HGA-BK, you press and hold Mode for 2 seconds until it goes into the setting mode. Then you can use the up/down arrows to cycle through the Time Zone options. (1 is Pacific, 4 is Mountain). Press Mode again to confirm the setting and advance to the next item to change. You will leave the Set mode if you do not press a button for several seconds. If you just press and release the Mode button, then you can set the time display option.
A number of Oregon Scientific product manuals are available here:
Technical Support , http://www.oregonscientific.com/us/en/service/support . Scroll down and see the drop-down menu on the right.
I hope this helps.
Jan 25, 2014 | Garden
My oregon scientific projector clock keeps changing time, I think it might be something to do with the time zone. I do not know what a time zone is?
A time zone is section of the country that adjusts for daylight savings time. The United States is composed of four time zones - Eastern, Central, Mountain, and Pacific. Each county is assigned to one of the four time zones. See the attached map to see which time zone you are in. Then you must set up your clock to match that time zone. bblue1967191.jpg
May 03, 2011 | Vacuums
Oregon Scientific Model 323a--Atomic clock...the atomic clock keeps setting itself to one hour behind what time it actually is in my time zone...I mannually re-set the clock to the correct time...but when...
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
Mar 21, 2010 | Oregon Scientific RM323A Travel Alarm...
I have an OREGON SCIENTIFIC MODEL 323A travel alarm clock. I want to set it to East Coast time. It's presently on West Coast time and nothing I do to the front panel buttons will allow me to change the...
The following is from a manual I found online. Step 1. and 2. worked to solve the same problem you're having for my sister-in-law. Hope it works for you too--good luck! JLC
SETTING THE CLOCK AND CALENDAR
CLOCK MANUALLY
1. Press and hold [MODE] button for 2 seconds.
2. Using the [UP]/[DOWN] button to scroll through the 4 U.S.
time-zones (Pacific, Mountain, Central or Eastern) or non-U.S.
cities. Press [MODE] to confirm.
3. If non-U.S. city is selected, the world time city will be flashing.
Use [UP]/[DOWN] to select the city (for city names abbreviation,
please refer to the section “Selecting the World Time”). Press
[MODE] to confirm.
4. Repeat the same procedures to set the hours, minutes, year, month,
day, language of day-of-week and hourly-chime on/off by using
[UP]/[DOWN] button.
Jul 11, 2009 | Oregon Scientific RM323A Travel Alarm...
I have a barolo atomic clock, batteries went dead.when I changed batteries I could not get the clock off of pacific coast time. bob pittsburgh
Make sure the day is displayed instead of seconds, then homd down the + button for 5 seconds. Every 5 seconds should advance it on zone. Had same problem and just got done resetting mine this way.
May 16, 2009 | Oregon Scientific FM Weather Projection...
Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
Feb 08, 2009 | Oregon Scientific Starck Large Music...
Accuwave DS Clock
The radio may not be able to get a strong enough or clear enough signal to process (night is best away from TV, computers and radios).  To regain "control" of the clock, take the battery out, wait 30 seconds and then reinstall it.  This will reset the clock.  You can then manually set the clock.
Press SET for a few seconds until the hour starts flashing in the display.  Then press the ADJUST button to set the hour.  Press SET to move to the different functions (Hour -> Minutes -> Seconds-> Month -> Date -> Year) each time using the ADJUST button to correct the setting.  Finally press MODE to exit the setting mode.
If the time zone is incorrect for your area (default is PST), press MODE to enter the Alarm Time Mode; then press SET to flip through the time zones; then press MODE again to exit.
The little "reset" is for use if the LCD display doesn't come on when the battery is changed. It doesn't affect any of the clock settings per se.
Nov 02, 2008 | Audio Players & Recorders
Oregon Scientific Starck Large Music PSL03A Clock Radio Logo
1,752 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Gyula Lacz
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
