Question about Nikon Coolpix 5400 Digital Camera
Monitor My Nikon Cool Pix 5400 monitor is blanked and I tried to turn on & off the monitor button without any luck...Do you have any idea??? Tom
  • 3 Answers
Re: Monitor
Td48: Have you tried pulling up the menu? Rotate the dial on the top of your camera to the setup tab while your camera is charged and tell me if you get anything on the display. if you do but the camera takes black pictures then you may be experiencing the same issue many others are and there is an official Nikon service bulletin.
Go to:
and check out solution #3. This will direct you to Nikon support should your issue be what is described in that thread.
Posted on Dec 23, 2007
0 characters
3 Points
NIkon cool pix 5400 will not turn on. Battery is fully charged.
A couple of possibilities. The battery is bad and not accepting a charge. Replace the battery. The battery terminals are dirty. Using cotton swab and some isopropyl alcohol, clean then fully dry the metal contacts on the battery and inside the battery compartment. Before turning it back on, be sure everything is fully dry.
Jun 26, 2016 | Nikon Coolpix 5400 Digital Camera
Cool pix starts then turns off with dark monitor
Replace the battery with a new, fresh one.
Jul 12, 2014 | Nikon coolpix S360
My Nikon Cool Pix L810 is brand new. Placed batteries in camera (that it came with) and it would not turn on after pushing on/off button. Replaced batteries with a new set and my camera still will not
I suggest you return the camera to the shop where you bought the camera for a replacement or warranty repair. If you try to fix it yourself you may void your warranty.
Mar 17, 2013 | Nikon COOLPIX Digital Cameras
My nikon 5400 scenic menu does not work. I cannot choose from its menu.
using the Monitor options you can control the quality of the preview displayed in the monitor, the conditions
under which the monitor will turn on automatically,and monitor brightness and hue.
be sure the monitor is on.the scene mode won't work unless you have the monitor on.
hope this helps.
Jan 01, 2011 | Nikon Coolpix 5400 Digital Camera
Nikon cool pix l100 is there a way to adjust
Are you sure it's really turning off? My camera goes into a "sleep" or power down mode....a slight pressure on the shutter button wakes it up and it's ready to shoot.
Mar 28, 2010 | Nikon COOLPIX L100 Digital Camera
The monitor is blank and camera will not zoom.
Try to reset the camera. That worked on mine.
Jul 22, 2009 | Nikon Coolpix 5400 Digital Camera
Nikon Coolpix 5400 lines in pix
Yes! Send the camera to Nikon with the service form. It takes about 3 weeks, free of charge.
Nov 05, 2008 | Nikon Coolpix 5400 Digital Camera
LCD blank & No picture taken
This appears to be a well known CCD problem, which Nikon acknowledges only for the COOLPIX 3100, 5700 and SQ models. Nikon denies the CCD problems on the 5400 are related, even though a Google search for this problem returns numerous results which claim the same defective Sony CCD sensor was used in the 5400 as was used in the 3100, 5700, and SQ models. See this reference:
Jan 02, 2007 | Nikon Coolpix 5400 Digital Camera
Nikon Coolpix 5700 - Blank Viewfinder/Monitor
This is a known problem with the CCD - Nikon will replace at no charge. Go here:
Nov 21, 2006 | Nikon Coolpix 5700 Digital Camera
Blur on LCD and on pictures taken
Sorry to tell you this but your CCD is gone. In a fwe days time pics will be black in color. CP 5400 uses a batch of defective Sony CCD's. Nikon's service center in Kolkata, India replaced the CCD in my CP 5400 free of cost. This was because Nikon has issued a service advisory. Try your luck with the Nikon service center closest to your home!
Jun 06, 2006 | Nikon Coolpix 5400 Digital Camera
Nikon Coolpix 5400 Digital Camera Logo
71 people viewed this question
Top Nikon Digital Cameras Experts
Are you a Nikon Digital Camera Expert? Answer questions, earn points and help others
