Question about Panasonic Televison & Video
MY PT-56hx41pf has startes to flicker and then go black. It will come back from time to time but is very dark and flickes in and out. Can you help?
    Champion:
  • 230 Answers
Hi, thank you for visit fix ya.
Here your solution:
Replace STK 392-110 with stk 392-150 ( better), check any resistor beside stk ic , burn or open .
If you have any question, I will be here.
Thank you
Posted on Jul 26, 2009
Dell Inspiron 2350 All-in-One Desktop PC Fault Flickering Touch Screen
It could be 1 of 2 things, either your monitor is going out on you, or your graphics adapter is going bad. Depending on how long ago you purchased it, and from whom, I would contact Dell service to find out if they can return it, or give you any suggestion.
May 19, 2014 | Dell Computers & Internet
Panasonic (PT-56HX41PF) rear-projection tv with no picture
The three blinks indicates a convergence IC fault. The convergence ICs must be replaced with the manufacturer replacement part. Use only the original replacement part. Your set uses STK392-110 convergence ICs.
These ICs are mounted on a large heat sink. Yes, you can replace it yourself and save few hundred bucks. But you must be knowledgeable enough on how to solder, resolder and use a multimeter.
You will need:
  1. Convergence ICs
  2. Heat sink grease or thermal compound
  3. Soldering iron
  4. Solder lead.
  5. Digital multimeter
  6. Solder pump
  7. Small side cutter
Feel free to inform me if you decide to replace the ICs yourself
Dec 03, 2009 | Panasonic PT-56HX41 56" Rear Projection...
Set shuts itself off. Power light flickers three times. I power down the tv and pluged it back in. It turned on but after about 2 mins, it did it again. Powered itsself off and with the power...
thats the error for convergence shutdown, You can get the PT53WX53 convergence repair kit at the following link www.tvrepairworld.com which will usually repair that issue. The kit contains the parts and CD with detailed instructions
Sep 10, 2009 | Panasonic PT-47WX53 47" Rear Projection...
The screen on my packard bell laptop flickers. It is approx 1 year old. This happens if it has been on a while or has just powered up, when plugged in or running on battery regardless of what it is being...
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | Packard Bell Easy One Silver 2120 Notebook
Replace IC Convergance chip in Panasonic PT-56HX41PF
Enter the tip of a pointed knife between the left side edges of the connector (circled in black in the attached pic) and gently tilt the knife away from the connector. Do the same on the right side. The connector should pop up.
Jan 21, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
Dec 29, 2008 | Toshiba Televison & Video
Wont turn on C-160, flicking screen
Dear emjay187,
i have the same camera and experiencing the same problem, it doesn't matter what batteries i put in (fully charged rechargables or dry cell AA) the low battery icon flashes then the screen flickers and goes off. i suspect it to be another onboard battery so i have found a small button 3v battery soldered to the main board. i have desoldered it and am now sourcing one so when i find it and try it i will contact you to confirm my results.
regards
Michael.
Nov 20, 2008 | Olympus Camedia C-160 Digital Camera
Interested in an older model panasonic
You can not buy a extended plan. I would pay no more than 500.00 for a excellent condition and picture quality.
Nov 17, 2008 | Panasonic PT-56HX41 56" Rear Projection...
Channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Mar 25, 2006 | Sony KV-32S26 32" TV
Televison & Video Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
