Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
We have an electrolux 26.0 cu.ft. side by side for 2 months and there is frost build up in the freezer and freezer door. What is wrong with it.
  • Anonymous Mar 31, 2014
    middle freezer basket keeps coming off track... maybe there is an issue with the guide rail on the right side?
    Problem Solver:
  • 19 Answers
I had the same thing with my Refrig/Freeze and the repair guy said that most times its a leak around the door seal. Take a piece of paper and put it between the door seal and where it touchs the freezer close the door see if the paper pulls out easly, if it does then you have and air leak, repeat it all the way around the door. Check the bottom side carefully. One other thing check the tempeture in the freezer it only needs to be between 0 and -5. Too cold will also cause air to be pulled through the seals.
Posted on Jul 26, 2009
Frigidaire Electrolux Frost Free Freezer
Sounds like you need to check if the unit went into a defrost cycle and made any ice build up inside the cabinet "slushy" and the water leveling itself and running down plastic liner parts to a place where it can escape underneath.
Jul 31, 2012 | Electrolux Frigidaire 16.7 cu. ft. Upright...
Fghs2665kf2 side by side freezer works fine fridge side warming up
The leading cause of the refrirgerator not working while the freezer is is good,is a defrost problem,do you see a bunch of frost built up on the back wall inside of the freezer?? If yes ya see frost build up of frost in the freezer it will be a problem with the automatic defrost system. This tip i wrote covers what to check when it isn't defrosting by itself.
http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 08, 2011 | Frigidaire Side By Side Refrigerator 26...
Side by Side GE Refrigerator freezer will not defrost which allows frost/ice to build up. I have cleaned all the areas behind the unit as well as under the unit. After I manuely defrost the freezer it...
The defrost circuit has failed in your fridge. Typical failure is with the defrost heating element. To troubleshoot, you need to remove the remove the contents of your freezer section and remove the freezer back panel to access the evaporator coil. You will need a hair dryer to melt the ice on coil. The heating element is attached to the coil. Use a meter to confirm that the element is bad. Hope this helps you.
Nov 08, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
3 1/2 year old whirlpool side by side has frost and ice building up inside the freezer compartment close to the door. Freezer seems to run continuously also...help?
hi ,
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck
  6. 911servicetoday.com
Jan 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer has alot of frost build up and the refrigarator has water leaking and running under vegetable trays in bottom and freezing what could be wrong It is a whirlpool top freezer 21 cubic ft and is 2...
Hi, this sounds like a problem with a blocked defrost drain. For full instructions on clearing the drain from my tips click HERE . If you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer and Refrigerator are not getting cool enough
there is more ice built up behind the panel
defrost is not working
Jun 27, 2009 | LG 26 Cu. Ft. Side By Side Refrigerator...
Side by side Admiral freezer that has frost
Check condensation drain line for a blockage.
May 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
No water is going into the trays
check water valve or filter icemaker befor calling service see if you have frost build up in freezer
Apr 02, 2009 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire sidebyside
suspect this is a frost-free type. if so the prob is with the defrost circuit. to check, remove back panel of freezer and see if there is a build up of ice
Mar 20, 2007 | Frigidaire Gallery Side By Side...
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
343 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
