Question about Hitachi Televison & Video
I can't get it to go off DTV configuration screen. We just used to watch Sky TV via the AV1 Scart setting, but due to some accidental button pressing, it got ont the DTV setup screen and we can't move it off there. It looks for channels, but as there is no aerial connected, finds none, then goes back to the configuration screen. I thought it was a problem with the remote control so got another one, but still no joy...What do I do? Do I need to chuck away the telly?!
  • 3 more comments
  • kirstie_rodg Jul 26, 2009
    Its a RCTD-1522 sorry if i posted this in the wrong place, it's just an ordinary telly...
    its a hitachi RCTD-1522
    its a RCTD-1522 hitachi
  • Travis
    Travis May 11, 2010
    Do you know what type of T.V. this is?
sreekidu
  • 60 Answers
SOURCE: av channel change
Hi, please check if there is enough air flow where tv's ventilation is placed.. Try to keep a pedestal fan close to the tv's air flow holes and check if it happening again.. i think this will mostly solves your problem. If you go with this to your service centre they will simply replace the Tuner,and will give you heavy bill. all the best sreejith
Posted on Jul 16, 2007
Benimur
  • 6966 Answers
SOURCE: Connecting up CRT TV, VCR, DVDR and digital box
With the indulgence of Mrvica, it would seem you posted the same concern twice. Here is a link to your other post with responses from xx and this responder.
Hope this be of help/idea. Pls post again should you need additional information.
Good luck and kind regards.
Posted on Jan 31, 2008
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
SOURCE: Set up new panasonic th-37px80b
The set is in the service mode. TO EXIT THE SERVICE MODE PRESS VOLUME DOWN ON THE SET AND THE OK BUTTON ON THE REMOTE F0R 3 SECONDS.WHEN SELF CHECK SCREEN APPEARS UNPLUG THE UNIT. Solution found on Fixya by QTV1 posted on Nov 20, 2007
Posted on Mar 08, 2008
SOURCE: Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Posted on Mar 24, 2008
I have connecting TV link with coax cable from my sky box to my LG 50PH660V 50-inch Widescreen 1080p TV But I can not get the sky to come on my TV. as channel 68 is DTV and on my remote it says TV/RAD
If I understand your problem the Y splitter is a passive splitter which mean that the centre pins are connected via capacitors this will degrade the picture on one or both outlets, the Sky box should be connected via a scart or HDMI connection
Feb 03, 2015 | LG Televison & Video
Tv dvd and sky box
isn't there any manual/ book?
To connect TV to Sky Box VCR, connect the SCART lead from the AV1 socket on the TV to the TV SCART socket on the Sky Box. Connect another SCART lead from the AV2 socket on the TV to the AV1 socket on the DVD player and an RF cable from VCR to the aerial in socket on the TV.
Apr 27, 2013 | Televison & Video
CAN I STILL WATCH SKY TV THROUGH MY TV WHICH HAS FREEVIEW BUILT IN
yes...via scart or hdmi (depending if you have sky hd) tv will need to be set on AV1 or HDMI channel when watching sky tv. normally selected on your tv remote with a button with a square and an arrow pointing into it or simpally AV written on the button.
Mar 19, 2010 | Sanyo Televison & Video
The sound isnt being played through my bush cht2dvd home theatre kit when im watching tv only when im watching a dvd its connected to my tv with a scart cable, Help please.
Hi Hoggy - do you still have the problem?
One way I found to solve the problem - if you have a Sky box (I actually have Sky+), connect the AV cable between the back of the Sky box and the Bush system. Then using the 'source' button on the front of the Bush - select AV1 (or AV2 depending on which AV sockets you plugged in to).
(Of course - will only work when watching a channel on the Sky box)
Steve (stevemweiner'at'gmail'dot'com)
Dec 25, 2009 | Audio Players & Recorders
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
How do I retune my Thomson Digital TV 24WK25UG after digital switchover in Granada area
this tv is not a dtv tv you can only watch digital tv if you now have a freeview box this is conected via a scart lead . you select av on the tv remote . or you can watch sky or cable . these are connected the same way .
Dec 04, 2009 | Thomson 24WK25U 24" TV
How do i connect dvd recorder to tv only receiving sky channels through skybox
If you have two scart sockets on your tv,then connect a scart from av1 on the dvd into the tv,then connect a scart from the sky box into av2 on the dvd,your recording channel on the dvd will be av2.
If you only have on socket on the tv,then connect a scart from av1 on the dvd into the sky box,your recording channel will be av1,connected like this you may have to turn off the sky to watch dvd`s.
Oct 30, 2009 | Televison & Video
How to set up Archos DVR Station but unsure how
Hi awillis98 this is Mike Houston of DISH Network, with the Archos DVRstation there will be a USB connection from the device to the DISH Networkreceiver, one the DISH receiver has recognized the external hard drive you willsee pop-ups on the screen that will walk you through the steps to configureyour Archos device. I will send a link to help with the setup for the externalhard drive. http://www.dishnetwork.com/SupportSection/setup-ehd
Apr 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
RECENTY PURCHASED SECOND HAND TV WITHOUT REMOTE OR HANDBOOK CANNOT SEEM TO SET UP MY SKY BOX TO IT ANY SUGGESTIONS?
Does the S/H TV have AV1 & AV2 settings and a scart socket? If so just connect the a scart lead from Sky box to TV and select AV1.
If you have no scart socket on the TV you need to connect a coaxial (aerial) cable from the sky box to TV and tune in to a channel. It is possible to tune in your sky remote if you have the TV code.
Please remember to rate this solution.
Oct 22, 2008 | Televison & Video
Hi.
3)
Chris.
Jan 30, 2008 | Televison & Video
Televison & Video Logo
96 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
