Question about GE Refrigerators
Ice dispenser/Water dispenser not working
The Ice and Water Dispenser will not dispense anything at all and the display keeps flashing ''0'' across the line. It makes ice but won't dispense anything!
  • GE Master
  • 4,654 Answers
I will need to get your model number to help you better. Thanks Sea Breeze
Ice dispenser/Water dispenser not working - d7e5c64.gif
Posted on Jul 26, 2009
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
Water dispenser not working. The ice dispenser will work but the water will not. I held it down for 2 minutes to be sure there was no water in the line but its still not working. We also changed the filter...
Check in the back wall of the refrigerator section and confirm the water dispenser reservoir is not frozen.
Listen for the solenoid valve to click when actuating the water dispenser. If no click check the solenoid valve.
The wires for the switch are in the door hinge of the freezer. Confirm that they have not failed.
Hope this is a helps?
Jun 18, 2017 | GE Monogram Side by Side Refrigerator
Whirlpool side by side model # ed25uexhw00
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by Side Refrigerator ice/water dispenser computer problem
You either have a loose wire or you'll need a display board. The only other cheap thing that you can try is to unplug the unit and plug it back in. But if that doesn't work then it's one of two things. Are you sure that you don't have a extended warranty on this unit? Is this a GE unit?
Aug 12, 2009 | Refrigerators
The water/ice dispenser will not dispense neither ice nor water..
There is a door switch that senses the door being closed for the dispenser to work. The water problem could be a plugged filter if you have one. Was the frig extremely cold recently? The water resevoir can freeze up. (its located behind the crispers) It could be the switches in the dispenser itself. Process of elimination will lead to the problem.
Eric
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
No water from dispenser
chances are dispenser board is bad check power going in the board should be 120 volts and power out if no power out replace board
Dec 17, 2007 | Kenmore 25.1 cu. ft. Side-By-Side...
Refrigerators Logo
144 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
