Question about GE WBVH6240F Front Load Washer
I ran the test program and found faults
Located inside the top panel of the washer is a printed tech test program.
error on t02 was E70 meaning key stuck. I pressed every button and each key responded appropriately.
t08 the hot water valve would not work at all. We switched connectors from hot pump to cold pump and the program test ran. So we are pretty sure the hot water valve needs replaced.
t10 tt (tumble tub) did not work at all
t11 spin speed test it would not spin at all.
t06 the over fill and empty didn't automatically work or we chickened out thinking it was too full and the seal was going to break.
The washer will not function past the lock tumble unlock, lock and fills on cold water only.
the washer started out not running any hot water programs. It would work on cold water settings. Now it won't wash at all. If we replace the hot water valve will the tumble and spin problems miraculously disappear?
  • 770 Answers
No you will need to check the motor controller board
Posted on Jan 26, 2008
This is wierd, but I changed the water valves, unfortunately, the company sent me a replacement that was not exactly the same, I drilled one hole and mounted the new valve set. After installing the valves, I ran the machine in order to run the diagnostics, all worked, and all is fine now. Going on nearly two months, and all stil seems to work. I believe the hot water valve was shorted out, causing the computer to crap out...
Posted on Jan 29, 2008
Error code E70 What is it?
E70 Stuck key Continuous key read for 60 seconds. Power down (unplug) machine, wait 30 seconds and retry. Use t04 test to test keys. Separate control and control housing from front panel - clean and remove foreign debris. Ensure all keys can be operated freely without sticking. Replace control panel if actions do not resolve. Maybe this will help
Oct 27, 2013 | GE Adora Front Load Washing Machine Washer...
FL GE Adora Washer - WHDVH626FWW, will not spin, clothes come out wet. When I run "rinse and spin", water comes in, but drum only spins initially left half turn, then right half turn, never spins...
Hi Walter:
In oreder your diagnostic, that means that your motor control board has faild and needs to be replaced. This part is located behind the lower front panel. if you remove the screws along the bottom of the lower front panel, you can then pull the panel off and the control board is on the left side with all the wires going into it.
You can replace it yourself if you'd like, you will need to remove the lower front panel to gain access which is probably the hardest part. And you can order the part from Repairclinic.com if you have a full model number if you wanted to.
You need the motor control board. Here is a link to the part for your model number: PartDetail/Control-Board/WH12X10418/1475761
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 11, 2011 | GE WSXH208A Front Load Washer
I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
How to run a diagnostic test:
  1. Unplug power cord, then wait 30 seconds.
  2. After plugging in, follow these instructions...
To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
  • "t01"
    Model ID
    Verifies (or sets on new board) the proper Model id
  • "t02"
    Error Codes
    Lists up to 10 control-detected problems
  • "t03"
    Software ID
    Verifies using latest Control-eePROM-lnverter software
  • "t04"
    Exercise lCD/lEDs
    Verifies that all the displays and buttons work
  • "tOS"
    Pump Test
    Tests drain-out pump
  • "t06"
    Pressure Switch Test
    Fills to all 3 levels, then pumps out water
  • "tOT'
    ThermistorlHeater Test
    Verifies that both the Thermistor and Heater work
  • "t10"
    Tumble Test
    Verifies Washer Tumbles (I.e. Wash cycle)
  • "t11"
    Spin Test
    Verifies Washer spins
  • "t12"
    Dispenser Test
    Verifies Dispenser fill works-for all four fill modes
  • "t13"
    EOl Test
    Performs End-of-Line test sequence
Button Commands (based upon test mode)
t01 prerequisites: none
Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
Power Returns to "t01"
t02 prerequisites: none
Start Displays most recent error code (EOO=none)
Start Displays previous error code (up to previous 10)
Hold start Clear all error codes (and then displays EOO)
Power Returns to "102"
t03 prerequisites: none
Start Alternate "cod" and Control Software version
Start Alternate "EE" and eePROM version
Start Alternale "Inv" and Inverter Software version
Power Returns to "103"
t04 prerequisites: none
Start loops on lighting lED's, LCD and cycle ids
Any button Beeps when depressed
Power Returns to "t04"
tOS prerequisites: none
Start Displays "P" and pump for 60 seconds
Power Returns to "t05"
t06 prerequisites: none
Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
Start Fill, when reaches Main level-displays "nl"
Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
Power Returns to "t06"
t07 prerequisites: Main level pressure switch must work
Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
Power Pumps out water and returns to ''t07''
t10 prerequisites: none
Start Displays "It" and tumbles tub alternating the direction every 5 seconds
Power Stops tumbling and returns to "t10"
t11 prerequisites: none
Start Spins to 400 RPM displaying increasing RPM
Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
Power Stops spinning and returns to "t11" when stops
t12 prerequisites: none
Start Displays "pdt" and fills via pre-wash chamber
Start Displays "ddt" and fills via main wash chamber
Start Displays "bdl" and fills via bleach chamber
Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
Power Pumps out water and returns to "t12"
t13 prerequisites: none
Start Starts EOl test sequence (NOT used in Repair)
Power Returns to ''t13''
Once you have the diagnostic codes, check this post for the meaning of the codes:
http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Jun 25, 2011 | General Electric WCVH6800J Front Load...
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
Ge WCVH6800 front load washer. Power was interrupted during washing cycle. Machine counts down 3.6 minutes, then goes off. How do you correctly reset cpu or test system
Here how you "test" the system: http://www.fixya.com/support/t9576766-found_small_part While in test mode "t02", you can reset all the error codes by holding down Start until it displays E00. If you find errors in the t02 test, make sure you write them down before clearing.
Dec 11, 2010 | General Electric WCVH6800J Front Load...
What does error message E70 mean?
Remove the top panel and theirs a tech sheet that will tell you what the code mean
Dec 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Front load washer door locked
"F22" is a door latch error code. This could be a momentary program glitch, a failed door latch, a problem with the Central Control Unit (CCU), or the interconnecting wiring between the two. The following link explains how to troubleshoot the error and/or replace the latch if necessary:
http://www.fixya.com/support/r1976388-f22_error_code_whirlpool_duet_kenmore
Attempt to reset the CCU, first, to see if this is just a program glitch. Then, inspect all the interconnecting wirig between the latch and CCU to make sure you have good contact.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this particular error code.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
Apr 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
E70 message before last spin cycle.
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 07, 2009 | Kenmore 46462 Front Load Washer
GE Dryer error code E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code “E00”shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error “E00”code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
Mar 16, 2007 | GE DBVH512EFWW Dryer
GE WBVH6240F Front Load Washer Logo
177 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
