Question about Western Digital Caviar WD800JB Special Edition 80 GB Hard Drive
Technics sa-eh790 will not come out of standby
The power switch or the remote will not bring the unit out of standby, red mains indicator on.
I would like to get a neew remote control for my stereo system model number CD stereo system panasonic SA-PM9
The Panasonic SA-PM9 indicates the main unit of the SC-PM9 CD stereo system. It came with the EUR7711140 remote. Amazon.uk has the original remote for sale here: https://www.amazon.co.uk/Original-remote-for-PANASONIC-SCPM9/dp/B01610BYJ8 . Other sites have replacements for this remote. One vendor with the replacement in stock (today) is http://www.remote-control-world.eu/rc-for-audio-hifi-panasonic-technics-c-12_96/panasonic-eur7711140-replacement-remote-control-p-3903 .
The manual for the SC-PM9 is available from Panasonic's support for the unit. The direct link to the manual is https://panasonic.ca/PCS/OperatingInstructions/SCPM9S-OI-Eng.pdf .
I hope this helps.
Feb 01, 2017 | Panasonic Audio Players & Recorders
Not turning on
The power supply has failed.
Nov 27, 2012 | Akai LCT3201AD 32 in. LCD Television
I have a technics SA-EH790 WITH OUTPUT PROLEMS
Check its speakers. Sometimes they might be out.
Jun 14, 2012 | Technics SCEH790 CD Shelf System
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
How turn off integrated philips 25PT2252
Switching on/off the Set:
• Press the main power button to switch on/
off the TV.
• If the set is on standby (indicator is red),
press the Power button on the remote
control to switch on set.
Jan 12, 2010 | Dell Inspiron 1501 Notebook
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
Need a new amplifer for a sh-eh790 as my main audio output has gone
before throwing out your old amp open it up and check the processor inside the amp its a little black thing behind the fan. if that dont work then contact me again. and i will suggest more things. but if you really want to replace it would you give me your old amp please and here is a link to a amp for you. i know its correct as i have the same system. I LOVE TECHNICS PRODUCTS. http://cgi.ebay.co.uk/Technics-SA-EH790-AMPLIFIER-/130501062833?pt=UK_AudioTVElectronics_HomeAudioHiFi_Amplifiers&hash=item1e627830b1#ht_646wt_1141
Nov 14, 2009 | Technics SCEH790 CD Shelf System
Only standby red light comes on. power button or
There is a failure on one of the circuit boards, and or the power supply itself. The main uPC, or the power supply controller is putting the main power supply in to protect mode.
You would have to send the set for factory service to resolve this issue.
Jerry G.
Oct 10, 2009 | iLO 3200 32 in. LCD Television
Western Digital Caviar WD800JB Special Edition 80 GB Hard Drive Logo
213 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
